6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
Pros and cons
Old May 25, 2020 | 07:42 AM
afisher80's Avatar
afisher80
Pros and cons
So dpf delete pipe and tuner but egr is deleted but still intact. What do u think
Old May 26, 2020 | 05:56 AM
DieselDenny's Avatar
DieselDenny
That's the way mine has been for 8 years, no problems.
Old May 27, 2020 | 10:15 AM
afisher80's Avatar
afisher80
Ok thanks. Did u have to do a cold air intake
Old May 28, 2020 | 08:22 AM
DieselDenny
No the rest is bone stock
Old May 28, 2020 | 04:25 PM
afisher80's Avatar
afisher80
As soon as I did all that my sensor went off said check air filter. I just put a new one in. so I thought it was something that came with the territory.
Old Aug 4, 2020 | 04:02 PM
Conner Stevenson's Avatar
Conner Stevenson
Lots of folks have that setup. You can take it as far as you’d like in relation to modifications. That’s up to you and how deep your pockets are.
Old Aug 9, 2020 | 07:25 AM
afisher80's Avatar
afisher80
Ty
I appreciate the feed back ty
Old Aug 22, 2020 | 09:49 AM
73fan's Avatar
73fan
The factory air box flows pretty good, and for the most part it suffices. You will notice though, that with the DPF gone, if you do one wide open throttle pull, the filter minder will be sucked in pretty much the whole way in. It’s not starving for air, but it is limited.
afisher80
19
Jun 2, 2020 09:25 AM
alawrence
6.7L Power Stroke Diesel
Sep 29, 2017 02:16 PM
13boostedbeast
May 23, 2017 07:29 PM
batfire2000
Feb 13, 2015 08:48 PM
kel1306
Sep 26, 2013 09:24 PM
