Door locks and lumbar support
Old May 24, 2020 | 07:26 AM
Brooks113's Avatar
Brooks113
My dads 93 f250 7.3 has around 200,000 miles on it .. recently the door locks and the lumbar support stopped working .. i checked the door switch and the seat switch for power and nothing. I check the fuse panel and I get power .. where else can i check to see where i am losing power from
also i pulled the door wiring back and probed the wiring there and no power or split wires
thank you for your help
Old May 24, 2020 | 07:42 AM
seville009's Avatar
seville009
I had to fix a Ford lumbar support once many years ago - can’t even remember the truck model
However, all the lumbar support was at the time was a piece of plastic between two metal supports that either spread apart of came together. It was accessed from the back of the seat just by taking apart the seat fabric (which was either velcro’d or buttoned in place). It was easy to get to and check
in my case, the plastic piece had broken. I think I just duct taped it back together
Old May 24, 2020 | 07:50 AM
Brooks113's Avatar
Brooks113
The lumbar support isn't broken the switch is not getting power and I dont know why
Old May 24, 2020 | 10:34 AM
lonewolf_'s Avatar
lonewolf_
Scope Wizard
it's all powered from Circuit Breaker #12 no fuse..... it's a Black/white wire for all the power feeds.
obviously if the Radio, Map lights, and Glove box lights then you don't need to dig in the engine compartment... your problem is from behind the under dash fuse box and towards the seats and doors.
Old May 25, 2020 | 02:02 PM
Brooks113's Avatar
Brooks113
is there a common place the wire could break or short out ?
Old May 25, 2020 | 02:27 PM
lonewolf_'s Avatar
lonewolf_
Scope Wizard
look at C200 that would be what I would suspect first IF you have power on both sides of Circuit Breaker. left Cowl location.
Old May 26, 2020 | 07:05 AM
Brooks113's Avatar
Brooks113
Thank you i will check it out today
Old May 28, 2020 | 11:36 AM
Brooks113's Avatar
Brooks113
no power at the conector c200
Old May 28, 2020 | 12:23 PM
lonewolf_'s Avatar
lonewolf_
Scope Wizard
ok so it's between that connector and the fuse box which would be Circuit Breaker #12
Old May 29, 2020 | 10:18 AM
Brooks113's Avatar
Brooks113
Followed the wire up and behind the dash found a small slice in the wire. Cut it out and replaced it with a new one and its working again thank your for your help
Old May 29, 2020 | 11:25 AM
lonewolf_'s Avatar
lonewolf_
Scope Wizard
good job ... glad ya got it fixed
Fue1ed by Ra9e
Jul 3, 2016 11:44 AM
jmuenchow
Jun 29, 2015 04:54 PM
beckman
Feb 20, 2014 03:09 PM
Xdaddy517
Mar 27, 2011 05:28 PM
alwaysfixingsomething
Electrical Systems/Wiring
May 23, 2003 09:25 PM
