Sponsored by: Auxito
Replace Brake Fluid
Old Oct 17, 2003 | 01:45 PM
Petiboy's Avatar
Petiboy
Replace Brake Fluid
Hi Folks,
I would like to replace my entire brake system fluid, Is there an easy way to rid the entire system of the old fluid so I can add new?
Thank you,
Old Oct 17, 2003 | 07:37 PM
HomerWinzlow's Avatar
HomerWinzlow
If it has ABS you will probably want a professional do it, as they can use a scan tool to bleed out the ABS hydraulic system.
