Cabin Air Filter
Old May 22, 2020 | 11:19 AM
pete500's Avatar
pete500
Cabin Air Filter
I have a 2000 F250 Superduty Stroker. Is there an AC/Heater cabin air filter in there somewhere? If not, can one be installed and where would be a good place to attempt it?
Thanks
Old May 22, 2020 | 12:06 PM
CousinCarl's Avatar
CousinCarl
Not from the factory. I think I remember someone putting one in behind the blower motor or hacking up behind the glove box (?) I'll see if I can find the write up of it.
Old May 22, 2020 | 12:18 PM
pete500's Avatar
pete500
Thanks CousinCarl,
I tried the search function on the site but didn't find much help. I was thinking of somewhere around the blower motor from under the hood and was hoping someone may have figured a good way to do it before I start my attempt to install a filter. Reason being is mainly the wife has asthma.
BTW...We are going to Haltom City near Ft. Worth sometime this summer.
Old May 22, 2020 | 12:44 PM
truckeemtnfords's Avatar
truckeemtnfords
Veteran: Marine Corps
The trucks did not have one but I remember reading that the Excursions did and there used to be a retro-fit you could do from Ford but I believe that has been obsolete/discontinued for years. If you find out something different let us know.
Old May 22, 2020 | 12:50 PM
CousinCarl's Avatar
CousinCarl
Originally Posted by pete500
Thanks CousinCarl,
Well, I struck out. I know I've seen it done somewhere. In my search, however, Cabfresh offers an aftermarket kit to install under the cowl into the HVAC system apparently. From what I read many say it's not worth the trouble (Ford apparently also used to list them in their catalog but had so much trouble and complaints they stopped from what I read) but if you care to investigate further... FITS: FORD SUPER DUTY PICKUPS 1997-2007 ? PART NO. 19200 | Cabfresh Filter Company
I'm about an 1.5hrs North of Haltom City
Old May 22, 2020 | 02:50 PM
pete500's Avatar
pete500
Thanks Guys,
Maybe I can design one that works well with what is in the truck already. Seems to me it can be done without making a big mess of things.
Old May 22, 2020 | 10:31 PM
SpringerPop's Avatar
SpringerPop
What are you trying to remove (filter) from the cabin air?
Pop
Old May 22, 2020 | 10:36 PM
pete500's Avatar
pete500
I'm trying to filter the outside air when the system is set to allow outside air in when the ac or heater is not needed.
Old May 24, 2020 | 06:37 AM
FordTruckNoob's Avatar
FordTruckNoob
Here was my attempt at it.
https://www.ford-trucks.com/forums/1...ir-filter.html
Old May 24, 2020 | 07:17 AM
SkySkiJason's Avatar
SkySkiJason
I have seen the evaporator almost completely blocked with dog hair and dirt. The blower motor and evaporator cover had to be removed to adequately clean it (PITA!!!).
First, I just reached through the blower motor opening and peeled of the outer layers of debris. Probably could have made another dog with that, but there was still ‘mud’ in the fins. Since I had the carpet out, I removed the evaporator cover and hosed it clean...
That said, I think you could just stick filter media there (blower side of evap) relatively easy. Just remove blower to service it a couple times of year?
Carolyn4
Oct 20, 2004 08:03 PM
spitball
Jun 20, 2004 06:55 AM
f350xlt460
Apr 24, 2004 09:31 AM
unclematty
Jan 7, 2004 08:02 AM
jeff1259
Nov 27, 2003 07:52 AM
