Sponsored by: Real Truck
2012 F250 DPF delete
Old May 22, 2020 | 08:38 AM
Nutter076's Avatar
Nutter076
HI Everyone. New here. Recently got a 2012 6.7 and just got a Exhaust fluid system error on the dash and a wonderful 50 mile count down to speed limitations.
I just bought a H&S tuner to do the DPF delete, but have not gotten a new exhaust yet. Can i delete the DPF system to clear the error without replacing the exhaust? I know i will need to eventually because of the filter clogging, but it wont be for a few weeks. Also, can you re-enable the DPF system if i wanted to put it all back in at some point?
Old May 22, 2020 | 08:52 AM
Evan_P's Avatar
Evan_P
No you cannot run delete tuning with the DPF still in place. You have to do the exhaust when you do the tuner. You can revert to stock with the tuner if you choose to put the DPF back on in the future.
Old May 22, 2020 | 09:04 AM
Nutter076's Avatar
Nutter076
Thanks for the quick reply! Curious as to why it has to be removed before/at the same time as the delete?
