Tranny Seal
Old May 19, 2020 | 09:24 PM
tommyleea's Avatar
tommyleea
Tranny Seal
55 F100 3 speed with R10 overdrive. I need the output shaft seal. Do I just order one for a T86 transmission, or is there a different one for the overdrive unit? Thanks
Old May 19, 2020 | 10:40 PM
52 Merc's Avatar
52 Merc
According to my old Ford parts catalog, it says Transmission Oil Seal, 48-55 F1/100 with light duty 3 speed, output shaft bearing retainer, 53-55 F100 with overdrive, overdrive housing, rear. Same seal, 21C 7052A.
Hope this helps.
Old May 20, 2020 | 12:01 AM
ALBUQ F-1's Avatar
ALBUQ F-1
Per NumberDummy: 21C-7052-A >> replaced by A2TZ-7052-A >> replaced by C4TZ-7052-A .. Oil Seal-Output Shaft
NAPA # CR 13639
https://www.napaonline.com/en/p/ATP1...ordInput=13639
Note this is a rubber lip seal, vs the originals that had felt in them
Old May 20, 2020 | 07:36 AM
tommyleea's Avatar
tommyleea
Thanks to all.
Old May 20, 2020 | 07:47 AM
green53's Avatar
green53
Didn't someone here also say a seal from AOD, National # 76925 work?
Old May 20, 2020 | 10:45 AM
ALBUQ F-1's Avatar
ALBUQ F-1
I have posted that before, actually it is National #7692S (S not 5). It will fit too.
PastorJ
May 19, 2020 07:53 AM
william16339
Sep 1, 2015 01:58 PM
jamhh
Mar 17, 2014 08:31 PM
Jacks 65
Sep 16, 2010 10:33 AM
