2009 3 valve
Old May 19, 2020 | 06:52 PM
dragford1's Avatar
dragford1
2009 3 valve
So I can’t get the truck to start. I can hear the fuel pump energize when I turn the key to on. I checked fuse 27 and the relay. Also replaced the fuel drive module on rear frame rail. Sprayed starter fluid in to try to differentiate between fuel/ignition. Still cranks but no start. There is fuel pressure at the rail. Ideas?
Old May 19, 2020 | 07:18 PM
dragford1's Avatar
dragford1
Add
I should add that sometimes while turning over, it sometimes feels like it is free spinning - then I can hear the compression cycles and it jumps a few times like it wants to start then won’t. Kinda like old school timing off -
Old May 28, 2020 | 10:50 PM
CathedralCub's Avatar
CathedralCub
FTE Community Team
I wonder about spark.
Old Jun 18, 2020 | 09:10 AM
dragford1's Avatar
dragford1
I have been messing with this no start condition for a bit - there are no codes except for an evaporative emission code. Checked all fuses. Replaced fuel pump module. A guy at the parts store mentioned the crankshaft and camshaft position sensors, but wouldn’t that throw a code if they were bad? Truck was running , then stalled and wouldn’t start since. Then sat for a year and a half til now.
Old Jun 18, 2020 | 10:53 AM
dragford1's Avatar
dragford1
Update - used my spark tester between the plug and COP while cranking and I have spark
Old Jun 18, 2020 | 08:54 PM
meborder's Avatar
meborder
An internal combustion engine bees three things to run
fuel
spark
compression
if you are positive you have fuel and spark, it’s time to do a compression check.
could the engine have jumped time?
Old Jun 19, 2020 | 08:54 PM
dragford1's Avatar
dragford1
So I said I have fuel at the rail. After researching , I am going to try to check the fuel pressure to make sure it is within specs. I have read 35 psi +\- 5 psi. Is that the correct pressure for “cranking” since it won’t start? And I can check it right at the valve on the driver side rail near the front correct?
Old Jun 20, 2020 | 08:52 PM
Tom's Avatar
Tom
I just looked up in the Chilton's manual, and the factory spec is 51 to 60 psi with the key on/engine off. No published spec for cranking, but it sounds like low fuel pressure may be your problem.
Check again by cycling the key and watching the pressure, if you get less than 50 psi you have a problem.
Old Jun 21, 2020 | 09:54 AM
dragford1's Avatar
dragford1
So with key on engine off, the pressure rises to about 40 psi then slowly lowers down to 5 or so. Is the fuel pressure regulator at the fuel pump itself? I am thinking I will do the pump, regulator and filter.
mkbuth
Apr 15, 2018 03:06 PM
TheWhiteBeast
59
Jul 25, 2011 09:24 AM
87 Ford Driver
Mar 3, 2011 10:16 AM
f1504x4driver
43
Jan 24, 2011 11:09 PM
gilllawn
Jan 16, 2006 01:38 PM
