Blue smoke occasionally?
Old May 19, 2020 | 02:28 PM
Shovelheadrob's Avatar
Shovelheadrob
I noticed a bit of blue smoke today, everything is running fine but, when cruising along at a steady slowish speed, around 1500rpm, a bit of blue smoke will start, it gets steadily worse. If I accelerate it will clear & at higher speeds or driving in traffic (on & off the skinny pedal) there's nothing.
I'm thinking a blocked breather, or pcv?
Any thoughts or suggestions welcome.
Old May 19, 2020 | 02:48 PM
BWST's Avatar
BWST
Got Data?
There's a couple of ideas from the following thread: https://www.ford-trucks.com/forums/1...e-smoke-3.html
@BigAlsPSD had some blue smoke and had low compression on one cylinder. His blowby check of the oil cap upsidedown on the fill tube showed it hopping a bit.
Other suggestions include a leaking turbo seal, putting some oil in the exhaust.
How does a CCT look on your rig? All cylinders contributing fairly equally?
Any codes?
oil in crankcase not overfull?
Old May 19, 2020 | 03:09 PM
Shovelheadrob
Just done a CCT, no 8 failed which I believe is normal, it was exactly the same last time I checked.
Oil level is low, just finished a 300 mile trip pulling my toy hauler this morning, I didn't see any smoke the whole trip.
Old May 19, 2020 | 05:56 PM
F0rdc0wb0y's Avatar
F0rdc0wb0y
injector O-rings or turbo possibly?? How many miles ya got on that thing?? I only ask cause of your sig
Old May 20, 2020 | 12:56 AM
Shovelheadrob
My truck now has 120k KM's, I'm probably gonna pull the turbo & have a look through everything on the intake, been thinking about upgrading the boots so just do it all in one hit!
Old May 21, 2020 | 02:31 AM
aawlberninf350's Avatar
aawlberninf350
It's a Van Gogh
If the turbo is out install bellowed up pipes.
Old May 21, 2020 | 02:55 AM
Shovelheadrob
I probably will, I've started another thread about what I'll need to get, I'm in the UK & want to do it all in one hit with minimal down time.
DEERSHOOTER
6.4L Power Stroke Diesel
Sep 15, 2009 08:27 PM
Joe Finn
1997 - 2003 F150
Apr 21, 2008 11:23 AM
ALL BOY
Dec 5, 2005 07:18 AM
mjnoakes
Dec 16, 2003 02:36 PM
