B-Pillar Swap
Old May 19, 2020 | 11:04 AM
CoffeeCrazy's Avatar
CoffeeCrazy
B-Pillar Swap
Hello, I have a 2019 STX Supercab, and ever since getting it I wanted to install the glossy black B-pillars on the exterior (mine are matte). I found an available part through the Ford website and was wondering if anyone had any good results buying an aftermarket one for cheaper.
On a side note, in
(and other F150 videos) they are using a red tool used for prying. Was curious what it's called so I can purchase one. Thanks.
Old May 20, 2020 | 05:19 PM
JKBrad's Avatar
JKBrad
Welcome to FTE CoffeCrazy.
The red tool is available at auto parts stores. It’s called a trim tool.
the only parts available aftermarket don’t replace those pillar trim pieces, they cover them. A Google search will show some. I would rather have the matte textured ones as the gloss black trim scratches super easy and shows swirls in the sunlight. I have thought a out ordering an OEM textured set the cutting the opening for the keypad.
Old May 20, 2020 | 06:22 PM
johnday's Avatar
johnday
Very true, they scratch if you even look at them too long. Instead of replace, why not vinyl wrap them?
Old May 21, 2020 | 12:06 AM
JKBrad's Avatar
JKBrad
That’s a better idea. I’ll have to see if a local vinyl shop will take on such a small job. Or I could probably remove them and try doing it myself.
Old May 21, 2020 | 06:05 AM
johnday's Avatar
johnday
It was easiest for me to leave them on the truck, and do them in place. The only one I did remove was the drivers door so I could disconnect the keypad.
It's an easy first time project, no complex curves or anything. When I went to apply the vinyl, I took a piece large enough to cover both pillars, squeeged it down, then cut a slit between the two pillars with an exacto knife.
I've gotta do this on my '20 before that plastic starts looking bad.
Old May 21, 2020 | 10:05 AM
GlueGuy's Avatar
GlueGuy
That looks real nice John. Where did you get the vinyl wrap stuff?
Old May 21, 2020 | 06:20 PM
johnday's Avatar
johnday
Thank you!
Pretty sure it came from these guys, https://www.metrorestyling.com/
Old May 21, 2020 | 08:37 PM
GlueGuy's Avatar
GlueGuy
Thank you very much. Holy cat excrement, they must have a bazillion flavors!
Old May 22, 2020 | 06:37 AM
johnday's Avatar
johnday
LOL, ya, they've got a pretty good sized selection. I need to get an order out myself, if I can make up my mind what I want.
Old May 31, 2020 | 08:38 PM
2004Limited's Avatar
2004Limited
That looks great !! Nice job.
Old Jun 1, 2020 | 08:08 AM
johnday's Avatar
johnday
Thank you Jim, very easy to do.
Kj.keiscome
26
Jun 7, 2017 10:41 PM
