changing venturi boosters
Old Oct 17, 2003 | 08:13 AM
351 power's Avatar
351 power
Can I change the venturi assembly on a 2150 carb to gain some cfm? I have a carb with 1.23 for a code and wondered if a different venturi [from a 1.33 carb] would do anything. Could there be any aftermarket venturis available?
Old Oct 17, 2003 | 03:49 PM
bubbaf250's Avatar
bubbaf250
First of all, if the booster venturis from a 1.33 carb are bigger than the ones in your 1.23 carb, they might actually reduce the airflow in the 1.23 carb because they intrude more in the main venturi flow path.
Furthermore, there are several features of the booster venturi assembly that are critical to the carb's calibration (or tuning), so the booster venturi assemblies from different versions of the carb are not directly interchangeable. Switching booster venturi assemblies between two carbs with different calibrations could really screw up the carb's performance.
Check out this thread for more info about how to improve airflow in the Autolite/Motorcraft 2100/2150 carbs:
https://www.ford-trucks.com/forums/s...threadid=128651
Old Oct 17, 2003 | 08:35 PM
351 power's Avatar
351 power
Thanks for the reply BubbaF250. My computer isn't taking me to the thread, only to the forums. I tried some searches and didn't find the exact spot though. I'll keep trying but maybe you could direct me abit further.
Old Oct 17, 2003 | 08:45 PM
bubbaf250's Avatar
bubbaf250
Maybe the URL got mangled when I copied it into the previous post. Try this link:
https://www.ford-trucks.com/forums/s...hreadid=128651
Old Oct 17, 2003 | 09:13 PM
351 power's Avatar
351 power
Thanks BubbaF250, I just found it. I have been looking at local salvage yards for a 2150 coded 1.33. I have been tempted to go for a 500 cfm 2v Holley or some such, but from some of your postings it seems I aready have a good carb. Presently I have a 2150 coded 1.23 rebuilt and working very well. Will the 1.33 give me a noticeable gain below 3500 rpm? Were there any larger 2150's?
MainetoDC
Apr 6, 2017 08:44 PM
AubreyA3
Aug 23, 2016 02:41 PM
wallysF100
Jan 4, 2016 06:44 PM
Warhawk
Aug 9, 2003 07:21 PM
Bull
17
Jan 31, 2002 09:38 PM
