Looking for replacement of badly rusted part
Rusted mount for line that goes into rear drive terrain
I'll take more photos if it is too hard to identify what it is. It's on the driver side and it goes down into the pipe connected to the differential , it has a rivet in it on the frame. Is there a online shop that sells this piece?
Also,t is there a site where I can easily look up diagrams for the name/part number of this stuff based on location of the part? Tried ford and multiple sites on Google and can only get parts list for maintenance.
Just look for an appropriately sized piece of angle iron, drill a couple of holes in it (1 for the hose, 1 for the rivet), drill out the rivet on the old bracket and replace it. The spring clip that holds the hose tight against the bracket can be bought here. That joint between the hard line and flexible hose will have to come apart first though. You may be looking at reflaring that hard line and replacing the flare nut along with the hose if it doesn't come apart clean.
And you bring up a good point....what do you suppose the rest of the hard line looks like?
Glad I asked you guys about this, I thought this was gonna be a simple rust frame clean up but I'm uncovering worms as the days go by. I removed the tank for the hutch and harpoon mod that I just finished. Was about to install it back after finishing the frame protection but looks like I need to hold off and replace these lines now. Will come back with updates after I find all the lines that need to be replaced with pics.
I was researching hard brake lines and replacing them with a long term solution. Decided to go with nickle copper but I don't want to pay for a brake line flaring kit that I will only use once. U nless there is a decent flaring tool that is not $200+. Is there a nickle copper kit for a 02 F350 long bed, ext cab 4x4 ?
I purchased my prebent SSTL lines from SStubes.com or Finelines.com. I think the whole truck kit was $250. That's everything new from the MC on downstream. New braided SSTL line to the front calipers, and a braided SSTL line to the rear axle. The short flex lines to the rear calipers aren't in the kit though.
Are they perfect? Nope. They need a little tweak here, a little tweak there. They are like 90% though.
I just "replaced" the hard line from the front to that very bracket on my truck. "replaced" in that I re-routed NiCu a different way to get it done. NiCu is very easy to flare with hand tools, but as others have said, SS pre-formed would be the way to go now that everything else is out of the way. Two thoughts though, be sure the replacement lines are correct. The flex line I received (from that bracket to the axle) was about two inches shorter than my old one and wouldn't reach.
And when you do put it all back together, be careful. When my line behind the tank failed, I assumed it was corrosion. But when I pulled out the old line, there was a very clear crimp in the brake line that I probably did when re-installing my tank a few years ago where it failed.
