For the OP... this is what i have waiting for when my 2020 comes in.. I'm sure there's other brands/options also.. just a simple spacer
thank you for cal for your info.....also spruce Willis that is the one I’m probably going to go with. Just price seems so damn cheap I’m in shock and want to be 100% sure that’s all I need lol....so used to paying high amounts for everything I’m thinking wow is this really all I need......
Dont worry, there's plenty more ways to spend on these trucks lol. You might want to look into replacement shocks, thats a prety common, and many would say much needed uograde. A decent set starts in the range of $350-500. You can spend way more than that, but on these ttpe of trucks, and for most peoples use there is no reason to.
I was the same way! As ForCal said, not a ton of feedback on these 20s yet for obvious reasons... But the few that I've seen with the 1.5" kit look great for what I'm wantin
will look into doing that....any brands you recommend checking out? I see fox everywhere.....also so far all I’ve done to mine is limo tint every window Including front ones and throw 55% tint on the entire windshield. ...35x12.5 tires and new wheels....also ceramic coated/paint correction for whole truck including wheels...next will be spray in bedliner and the level. Will probably find other ways to throw money into it ..would have lifted it but I am barely clearing garage as it is.
Let's see that wheel n tire combo! Just livin vicariously thru yall! Been waitin n wishin for mine since Dec..
went with the ford performance sport wheels .. Same day I did ceramic/paint correction. Tires are Nitto Ridge grapplers. Wheels are 20x8 ford wheels. Taken the following day on a very cloudy day.
I also took off hideous valance and replaced with tremor valance and replaced antenna with short one...bottom pic was taken with a different camera and appears darker than it is. But liked the way pic came out !
