89 7.5 fuel system question
Old May 16, 2020 | 12:02 AM
Matt89460's Avatar
Matt89460
Hello, this is my first post, so bear with me. I’m working on my grandfathers 89 F-350 with the 7.5. That has sat for 10 years, I’ve replaced several things including; the map sensor, front fuel tank and pump, fuel injectors, ignition switch, eec relay, and battery. I let the cylinders soak in marvel mystery oil before I installed the front fuel pump and tank. I don’t have the rear plastic tank clean yet, so I just connected the old fuel pump up to keep the fuel from pouring on the ground when the front pump is turned on. When I started it up yesterday day, it ran great for a few seconds then died. I tried a few more times, same result. My question is, will not having the rear pump/tank cause some kind of pressure problem resulting in fuel not getting to my injectors?
Old May 16, 2020 | 06:27 AM
My4Fordtrucks's Avatar
My4Fordtrucks
Was the fuel tank selector switch last on the rear tank when the truck was parked? My guess is that the dual function reservoir ( on the the driver’s frame rail) is stuck drawing fuel from the rear tank so you cannot access that fuel in the front tank. That is was happened to me when I put my truck back on the road which had been parked about 9 years. It left me stranded on the highway with a full tank of gas I couldn’t access.
Old May 16, 2020 | 07:39 AM
Matt89460's Avatar
Matt89460
Thank you for your reply. My truck doesn’t have that reservoir on the Frame. I was certain it would, but mine doesn’t have that or the external pump. I know the front pump is working. I hear it, and I disconnected the fuel filter line to see if fuel was going thru ( it was). I haven’t put in a new fuel pressure regulator yet, or checked pressure to the rail. I’m not sure if that could shut me down like this.
Old May 16, 2020 | 08:27 AM
subford's Avatar
subford
Sounds like you have a 1990 truck and not a 1989.
Old May 16, 2020 | 04:12 PM
My4Fordtrucks
What letter is in the 10th position of the VIN?
1989 is “K” ; 1990 is “L”
chipduff
Dec 20, 2012 04:10 PM
tiny_daily
Oct 3, 2012 07:31 PM
bobbyngeorgia
Mar 24, 2007 05:05 PM
don_m
Nov 7, 2005 05:06 PM
Ed Trethewey
Apr 11, 2004 11:00 PM
