For all you Guru's
I've had a 91 Ford Probe GT turbo (2.2) give to me (not the whole car just the turbo) and I would like to find out the specs. on it. I've got a 94 F-150 I-6 Iwas wanting to put turbo on and I was wondering if I could possibly use this turbo to gain a small increase. Also is it possible to use just one side of the exhaust to power the turbo, And the other side stay the way it is, And go into both inlets on the intake manifold from the intercooler?
I presume that just one side would power the turbo, and I dont want hella boost, just a little additive. But I need to know if only using one exhaust side would throw of the balance of the engine.
I used a turbo out of a Nissan 300ZX, which was capable to power a 3.0 liter to 6000 RPM's plus. So I figured I could run a 4.9 liter to 3000 RPM's plus. Everyone told me this turbo was to small for my 300, but I didn't expect to get much over 3500 safe RPM's out of this straight six anyway. I get to about 3500 RPM's and my engine starts starving for air. This is OK in a 7500 lb van, I still travel at 65 mph with no problem.
If I understand your question correctly, I would say this turbo will be to small, you can't flow enough air through the turbo, for youe engine to breath properly.
Redneck-Cowboy
Hey E350turbo what did you have to calculate to get proper air/fuel mix, and does your turbo have water and oil inlets & outlets. What did you use to get the oil & water to the turbo?
All turbo's require a oil pressure line, and a drain back into the oil pan. I just ran a pressure line from the oil pressure sending port, to the turbo, and welded a drain tube onto the oil pan, and ran the turbo drain to it, just make sure the drain tube is above the oil in the pan.
I do have cooling lines also, they are not necessary, some people just bypass these. I decided not to, I just T'ed off the heater hoses. The coolant running through the trubo is just for added cooling when shutting the engine off. They aren't very effective.
