ABS Light.
Old May 14, 2020 | 05:06 PM
THE_PVZ's Avatar
THE_PVZ
ABS Light.
1993 F250 460 4x4 manual
My brake and ABS lights are always on. I did some searching and found that the cause is often a rear wheel speed sensor, so I replaced it with a new one. But the lights are still on. What is my next step?
Old May 14, 2020 | 05:19 PM
rla2005's Avatar
rla2005
If you have a red brake light on that will trigger the yellow ABS light to turn on as well. The most typical cause of the red brake lamp to be active is low brake fluid in the master cylinder.
Old May 15, 2020 | 05:25 PM
THE_PVZ's Avatar
THE_PVZ
My brake fluid was indeed low in the Master cylinder reservoir, so I topped it off and still no change. Thoughts?
Old May 15, 2020 | 06:24 PM
My4Fordtrucks's Avatar
My4Fordtrucks
Is the float in the reservoir floating or is it stuck toward the bottom?
Old May 15, 2020 | 09:25 PM
THE_PVZ's Avatar
THE_PVZ
I’ll have to take a look at that in the morning.
Old Jan 31, 2025 | 08:37 PM
timbuctooCal's Avatar
timbuctooCal
So what happened?
Old Jan 31, 2025 | 08:59 PM
AuroraGirl's Avatar
AuroraGirl
Originally Posted by timbuctooCal
So what happened?
If your having issues, starting a thread is the best way to get help
62FE4x4
Apr 13, 2017 07:54 AM
plessasrdjr
Feb 13, 2014 04:23 AM
forddriverdad
Jun 28, 2012 06:11 PM
krave
1978 - 1996 Big Bronco
Jan 15, 2009 11:28 AM
brianamb
Aerostar
May 20, 2007 12:58 PM
