Brake / ABS Lights
Old Apr 12, 2017 | 12:12 PM
62FE4x4's Avatar
62FE4x4
Brake / ABS Lights
Any idea what would cause the brake indicator and ABS light to come on whenever you hit the brake pedal? The come on simultaneously. Thanks any opinions welcome
Old Apr 12, 2017 | 12:16 PM
madpogue's Avatar
madpogue
Yeah, it means your brakes may fail at any time. Have you checked the brake fluid, and checked the wheels and ALL lines for leaks?
Old Apr 12, 2017 | 12:24 PM
62FE4x4's Avatar
62FE4x4
Absolutely. No fluid leaks; reservoir is full. Brake light sensor on the master cylinder is new, and the abs sensor is new as well.
Old Apr 12, 2017 | 04:16 PM
rla2005's Avatar
rla2005
The Red Brake light is triggered by low fluid in the master cylinder. You may have a bad float inside the master cylinder if it really is full.
For reference (lower right hand corner of the photo:
1995 F series. Other years are similar.
Old Apr 13, 2017 | 07:54 AM
62FE4x4's Avatar
62FE4x4
There are more codes to set off the red indicator light than just a low reservoir. The sensor on the parking brake pedal for instance. Neither of which would set off the ABS Light simultaneously. I replaced the pressure switch on the brake pedal that shuts the cruise off. That seems to have eliminated the issue. Thanks for all the input.
Peggy
Sep 22, 2013 09:29 PM
gbeau626
Apr 9, 2010 10:18 AM
Kijutsu
1997 - 2003 F150
Mar 18, 2009 07:23 AM
krave
1978 - 1996 Big Bronco
Jan 15, 2009 11:28 AM
damajikninja
1983 - 2012 Ranger & B-Series
19
Sep 18, 2006 12:42 PM
