Measurements requested
Old May 12, 2020 | 06:42 PM
Dweber85rc's Avatar
Dweber85rc
I did some searching for this measurement but didn't see it. I just about ready to pull the trigger on getting 4inch pro comp lift springs for my excursion. Trying to guess total height of the vehicle to make sure before I go ahead with it that it will still fit in the garage. My door opens at just a hair under 90" right now. I could maybe squeek another inch or so out of the opener by adjusting it to open a little more. If I am measuring this right I am right now at 82 inches at the tallest point of the roof rack. Add 4 for the lift, I'm at 86 inches and add 1.5 for the increase in tire size, which puts me then at 87.5. Leaves me 2.5 inches with the current overhead door configuration. For those who have done this lift and went with a "35" inch tire, is that estimate pretty close? Or can you measure yours and tell me what yours is at.? My wife will not be happy if her truck doesn't fit in the garage!
Old May 13, 2020 | 12:03 PM
Squirrel13's Avatar
Squirrel13
Not your specific options but I have about 2.5" of spring lift on 285/75/17 tires and the Rhino Rack Pioneer Platform. Full tank of full from floor to top of rack deck is 85.25"
Old May 13, 2020 | 01:16 PM
96firephoenix's Avatar
96firephoenix
You'll probably want to swap out the factory whip for a stubby antenna. OE whip sticks up about another 3" above the roof, and slaps around on the underside of the door as you pull in.
Another consideration: your OE springs might be pretty badly sagged, so a 4" lift kit might actually raise your overall height more than 4"
Old May 13, 2020 | 01:26 PM
Dweber85rc's Avatar
Dweber85rc
Good to make note of. I will go back and measure the hub to fender for the rear to determine how bad they are sagging. I know the fronts are sagging a little bit.
Old May 13, 2020 | 02:46 PM
Squirrel13's Avatar
Squirrel13
When I did my V/C springs I gained a solid 2.5”
Old May 13, 2020 | 07:32 PM
Dweber85rc's Avatar
Dweber85rc
My rear is at 24.
Ultraboy
Dec 3, 2013 11:48 AM
JOHN2001
20
Jan 7, 2011 07:38 PM
johaner78
Jan 28, 2010 03:48 AM
codyingersoll123
Nov 26, 2009 01:41 PM
needfordlook
Apr 5, 2007 09:54 AM
