Possible Pcm problems!
Old Oct 19, 2003 | 09:25 PM
stepman's Avatar
stepman
Well ,I guess I was wrong. That is a TPS code ( voltage too low), so I guess you should have a look at that then.
Old Oct 20, 2003 | 01:49 AM
Hammy211's Avatar
Hammy211
Umm, didn't you say your engine seized up in another thread? Is that now revelent?
Old Oct 21, 2003 | 12:32 PM
94rangerprerunner's Avatar
94rangerprerunner
My 2.3l 4banger seized up, i'm just not having good luck with either right now.
Old Oct 21, 2003 | 12:35 PM
94rangerprerunner
I drove the truck for an hour yesterday, had the check engine light come on. When I got home I pulled the codes, and got: 122,172,176,186, 189. I don't understand what the last 4 mean.
Old Oct 21, 2003 | 04:13 PM
stepman's Avatar
stepman
122= TPS circuit below min voltage.
172= system indicates lean ( bank 1)
176= system indicates lean ( bank 2 )
186= injector pulsewidth higher or MAF lowerthan expected (w/out BARO sensor)
189= fuel system at rich adaptive limit at part throttle,system lean (bank 2)
Start by making sure your TPS is working right and then move on to check your fuel pressure. What does it drive like? Does it act like it's running out of gas or does it have a dead spot until you have your foot far enough in it? Sounds like your TPS is dead or your computer isn't getting the signal.
Is everyones connection on this site slooooow today or is it just mine?
Old Oct 23, 2003 | 11:04 AM
94rangerprerunner
I tryed switching the tps with my friends truck, and it helped alot, and there were no more codes. The thing is there was still that dead spot, it just doesn't drive to it's fullest.
Old Oct 23, 2003 | 11:49 AM
stepman's Avatar
stepman
I'd put a new one in it then and drive it a while. See if it "learns" itself out of it.
Old Oct 25, 2003 | 11:43 AM
94rangerprerunner
I put the new tps in, and it idles and runs better, but still has that dead spot. I'v ed replaced the fuel filter like 1000 miles ago. I don't know what else it could be. Got any ideas? I don't want to have to take it into a shop, beacuse I already have to drop a new engine into my 4banger. Thanks for the help
Old Oct 25, 2003 | 12:49 PM
stepman's Avatar
stepman
I'm currently out of ideas but I'll keep thinking. If you are no longer getting codes I think maybe go back and check timing and fuel pressure. May be runnning lean.
Old Oct 26, 2003 | 06:00 PM
94rangerprerunner
What does running "lean" mean? I think thats what some of the codes were, I started getting the same codes as before. When I accelerate I get this rattling under the hood then the check engine light comes on. I don't know what the problem is, but I don't want to have to take it to the shop.
Old Oct 26, 2003 | 10:28 PM
stepman's Avatar
stepman
"running lean" means that you either have too much air or not enough gas. Ideally we want to burn 14 parts air to 1 part gas....if we burn less gas(18 or 20 parts air to 1 part fuel) we are running "lean". Think of it this way....if you have a "constant supply of air" (all that the motor can suck in) but your fuel pressure drops resulting in less flow, you will have a leaner mix.
Old Oct 27, 2003 | 01:04 PM
94rangerprerunner
ok, I understand. Is there away to check to see whether the fuel filters clogged or not?
Old Oct 27, 2003 | 01:41 PM
  #28
stepman's Avatar
stepman
Check you fuel pressure. I wouldn't think the filter would be a problem with only 1k miles on it. You may have low pressure though.
Old Oct 27, 2003 | 08:09 PM
  #29
Ken00's Avatar
Ken00
Lean means that you have less gas in the mixture than the ideal amount.
Ianator
May 31, 2016 07:07 PM
78F460
Feb 8, 2016 09:32 AM
Larry Heath Wheeler
16
Oct 15, 2015 10:06 AM
AndeyHall
Jul 6, 2011 09:32 AM
