8BA Timing Marks
Old May 12, 2020 | 02:39 PM
arthall's Avatar
arthall
8BA Timing Marks
I have a ’53 F-100 with the 8BA flathead V8. The timing pin on the cam cover is easy to see and when I rotate the engine to TDC a small dowel head on the crankshaft pulley aligns with it. The pulley itself is rusty and I cannot see timing degree marks on it, say from 00 to 150 or more. Should the pulley have these timing marks? If so, they may just be covered with rust and need to be cleaned. If not, how do you time it to spec?
Old May 12, 2020 | 03:40 PM
ALBUQ F-1's Avatar
ALBUQ F-1
When the dot aligns with the pointer, the engine is at 2° BTDC, which is where the static timing is to be set (vacuum disconnected). There are no other marks.
Old May 12, 2020 | 04:13 PM
arthall's Avatar
arthall
Thanks for the info. Sounds simple enough.
v8only
Jan 16, 2016 10:36 AM
phurst
Mar 1, 2011 04:25 PM
mrshorty
2.6, 2.8, 2.9, 4.0 & SOHC 4.0 V6
Sep 10, 2003 05:56 PM
ramato
Aug 30, 2000 11:29 AM
samisage
Aug 4, 2000 06:41 AM
