1978 - 1996 Big Bronco
Shakes…Stalls
Old Oct 16, 2003 | 10:43 PM
unapro's Avatar
unapro
Unhappy Shakes…Stalls
I have a 1989 Eddie Bauer Ford Bronco 2D V8 Automatic Transmission. Today when I was driving it just started shaking a lot to the point that it stalled out. I got it started and looked at it at home. When I pressed on the acceleration in park the engine the entire engine started to shake a lot unnormally.
HELP!!! ahhhh any idea. ive been told something about a front end aliment or balancing but it seems like it could be more. Its havening a hard time moving forward .. or back wards for that matter
Old Oct 16, 2003 | 11:51 PM
andym's Avatar
andym
If it's doing it in park, you can rule out an alignment problem.
It would help if we knew what motor and transmission you're talking about. Have you had any problems in the past with it? Did it suddenly start happening? Does it happen all the time?
Old Oct 17, 2003 | 06:11 AM
unapro's Avatar
unapro
I will check today what motor and tran I have. This just suddenly happened and it does not happen all the time. I have been telling my friends that my truck has pms. Some times it works some times not. I’m just hoping I’m not destroying the thing.
Old Oct 17, 2003 | 09:38 AM
Kemicalburns's Avatar
Kemicalburns
have you done any work to your motor recently? I would check your plugwires make sure they are in good shape and in the correct order. you balancer on the crank might be shot or your tranny is low of fluid
Old Oct 17, 2003 | 09:50 AM
unapro's Avatar
unapro
i just put in a new radiator and new trany fluid
Old Oct 17, 2003 | 09:52 AM
Kemicalburns
how much tranny fluid did you put in. have you checked it sense you finished?
Old Oct 17, 2003 | 11:21 AM
unapro's Avatar
unapro
i checked it today when the engine is running. Its right. Some one else is telling me it sounds like its skipping a cylinder
Old Oct 17, 2003 | 12:45 PM
Kemicalburns
check your plug wire firing order. might check your timing as well
Old Oct 17, 2003 | 01:56 PM
mrit's Avatar
mrit
For a while after I bought by bronco I had a problem of the spark plug wires working themselfs off(Looked like they were still on, but they weren't connected). I pulled off the wires and bent the little pieces of metal in them so they clamped onto the plug better.
jamull2852
Modular V8 (4.6L, 5.4L)
Sep 2, 2013 04:25 AM
KristinHuff
Oct 14, 2011 09:42 AM
dpa_ford
1997 - 2003 F150
Mar 8, 2011 09:28 AM
tackelberry88
1997 - 2003 F150
Jun 16, 2010 08:58 PM
jpbrad0215
Aug 29, 2006 08:22 PM
