Update: It's Running!
Old May 12, 2020 | 12:20 PM
larg3n's Avatar
larg3n
Upgrades:
Comp 268 Cam
Comp push-rods
Comp lifters
Comp timing gear
Headman Headers
Offy intake
Holley 600cfm 4-barrel
Mechanical fuel pump delete -Holley Electric (carb specific) fuel pump
Old May 13, 2020 | 08:12 AM
1986F150six's Avatar
1986F150six
Nice!
Old May 13, 2020 | 08:31 AM
KubotaOrange76's Avatar
KubotaOrange76
Its Comin Right for us!
sounds good!
Old May 13, 2020 | 11:24 AM
AbandonedBronco's Avatar
AbandonedBronco
Sounds really good! How's it run?
Old May 18, 2020 | 12:16 PM
larg3n's Avatar
larg3n
So, far she is running really. I am not going to drive it much till I change the tires and brakes. I am about to change from 31x10.5 to 235/75. I did the back brakes the past weekend. So, by the end of this week I will be driving it regularly. I'll keep everyone posted.
Old Jun 1, 2020 | 06:55 AM
larg3n's Avatar
larg3n
UPDATE: I have been running the truck a few times a week, maybe 50 miles on it right now. I go to check the oil (I just changed it the day before) and its black and it does smell like gas. I have gas in my oil, and I know its not the mechanical fuel pump, because I don't have one.
Any suggestions where to start and what would case this?
Old Jun 1, 2020 | 07:22 AM
The Frenchtown Flyer's Avatar
Maybe a leaking needle and seat assembly or improperly set float level or excessive fuel pressure overwhelming the needle and seat.
Old Jun 1, 2020 | 07:40 AM
larg3n's Avatar
larg3n
Thanks french!
Also, every-time I run it, I have been pulling the first plug to inspect. So far they look clean. I am thinking I might need to adjust the fuel/air mixture and it is a new carb and I have adjusted anything on it yet?
Old Jun 2, 2020 | 07:53 PM
FuzzFace2's Avatar
FuzzFace2
Has the oil level gone up with this gas smell?
what temp Tstat you running in the motor?
When you are running the motor / driving the truck how long / far is it?
You have a working PCV system on this motor?
Dave ----
Tom
Feb 11, 2021 10:42 PM
lambchops25
1997 - 2003 F150
Jul 31, 2019 03:58 PM
Micbruff
23
Nov 5, 2014 08:17 PM
daisyq31
Escape & Escape Hybrid
May 8, 2013 10:25 AM
lowtrkn2k
Garage & Workshop
29
Oct 21, 2007 07:46 PM
