2005 f150 xlt 4x4 4hi works but 4low is not.
2005 f150 xlt 4x4. 4hi works but 4low not engaging. Doesn’t feel like anything is trying to engage. Shifts into and out of 4hi fine. Replaced both front actuators and solenoid. Also replaced the transfercase motor. Is the only thing that it could be is a broken transfercase? Or course there be a issue with vacuum or hub or something else possibly?
yes I have tried It with foot on brake and in neutral. Tried doing it from 4hi to 4low and 2wd to 4low neither is working. Tried turning off and back on as well. Will try again and try going backwards a little to. The 4low light is not coming on as well. It goes into 4hi with no issue.
If so, slow down and learn about how the 4wd system works. You're replacing the valve in your toilet when the kitchen faucet is dripping.
If you're not getting the GEAR REDUCTION of 4lo this has NOTHING to do with powering or engaging the front wheels. The GEAR REDUCTION happens 100% in the planetaries which live in the t-case.
Remove your shift motor and see if you can manually turn to 4lo. Try in N with parking brake set. Don't be afraid to try to rock either d/s to maybe aid engagement.
Also have a helper shift to 4lo and see if the motor is moving that far.
You need to figure out if the motor is capable of rotating enough to engage the 4lo position and if the t-case can physically be put into 4lo
Teach a man to fish.....
