Headers and Exhaust
Old May 11, 2020 | 11:28 PM
Crispy77's Avatar
Crispy77
Headers and Exhaust
Hey there,
I've recently happened upon a '77 f150. Only thing is, it has a 429. The exhaust manifold was broken and rewelded at some point in its life and is now splitting the weld and of course, exhaust leak. In the market to replace with headers and subsequent exhaust. It is 4wd so i need to account for that. Looking to go with 1.75" into 3" collector ( I like the deeper sounds ). Any advice on brands and their pros/ cons? Not looking to spend too much yet.
Old May 11, 2020 | 11:47 PM
broktruk's Avatar
broktruk
4wd headers for 429/460 arent cheap at all. Best thing to do is look em up, theres a ton of reviews on the few that are produced. If you find that you are going to stick with manifolds, I may have a set to pass along.
Old May 12, 2020 | 08:02 AM
77&79F250's Avatar
77&79F250
Moderator & parts slinger
Get your $ ready. https://www.summitracing.com/search/...ock-385-series
https://www.speedwaymotors.com/Patri...CABEgLu-PD_BwE
https://www.sandersonheaders.com/hea...block_429-460/
https://www.landlproducts.com/
https://maddogheaders.net/products/ford
4wd matters, manual or auto trans matters. Duel front shocks....That truck never came out with a 429/460 in a 4wd until the 80's.
Inside the frame rail exit can be a giant PITA and have front d/s clearance and cross member clearance issues. Outside frame rail exit has its own challenges, but not as bad.
Shorties, block huggers can cage and cook a starter. So think heat shield. Have you priced a replacement exhaust manifold?
Old May 12, 2020 | 06:35 PM
F150 grabber's Avatar
F150 grabber
Judging by my experience as well as others on this forum, stay away from l&l. Unless you enjoy cutting up your truck.
Old May 13, 2020 | 12:15 PM
Summitracing's Avatar
Summitracing
SPONSOR
With this swap, we have one set of headers that match your specs. Those are the fenderwell exit Hedman HED-85650. These will work with 4WD, but only with an auto trans.
To make headers fit modifications are likely. This is especially true with engine swap headers. You can view the reviews on our site for these. You'll see 1st hand fitment notes from our customers.
__________________
800-230-3030
www.Summitracing.com
grm61
Mar 14, 2009 11:59 AM
Bob07FX2
Exhaust Systems
Mar 11, 2008 04:31 PM
getandgo
Jun 10, 2005 09:32 PM
daveengelson
Exhaust Systems
Jan 30, 2004 09:56 AM
