I am pissed for 2 days I have been trying to install this headunit in my truck My friend is an ********* and never finished the job he was supposed to do today What I need is atleast a Wire Diagram for a 92 Eddie Bauer Series Explorer Also I need to know why my lights wont turn on in the Interior when this kid sparked some wires (No fuses are Blown) Please someone HELP!
Originally posted by Vanhecht sounds like your friend is an idiot figure out what he sparked too
Well, Yea he is, anyway, All I remember was that he was doing something and the wires touched and he blew the lights out which means the fuse should have blown which it wasn't, So I dunno, but I want to know how the hell am I supposed to do the wiring all I know is tommorow I will be going to end up going out and gettin some "Professional" do it for me since my "Friend" cut the Harness and stuff so I dunno.....
If you're sure that the fuses are all good, the next step is to check the bulb itself. If it's OK...time to start checking for stuff you don't want to find...like melted wire...
Also, maybe you'd better double-check that the fuses in the fuse box are of the correct amperage. It sounds like your friend's mishap "should" have blown a fuse.
Ok, if he cut the harness he's a moron, he's also a moron for not disconnecting the battery. You can buy a harness for 6 bucks that would hook up to the factory harness. It's not hard to install and you can find a diagram here. It's easy, don't get a "professional" to.
I also noticed that my battery level has gone down an extreme amount with in a day, When I turn the car on it goes back up to Normal I am just wonderin if that's normal (and thanks for the help that I have gotten so far) I am just so pissed that all this crap is happenin for something so simple!
Yay Got the Radio hooked up by a Pro only prob is I am missin a Harness that was hooked up to this big fat gray wire So my friend cut some wires and he didn't even need to what an *** hmm, Well does anyone know what that big fat gray wire is for Also, Where is my Factory AMP in my 92 Eddie Bauer Series Ford Explorer I'm gonna go search through forums but I just wana know. Because I can't hook up my speakers until I know what it's for an where the hell that harness is Well please someone Help me!
You can still hook up your speakers then change the amp later. Or are you sure that you have a factory amp? I have no idea what the grey wire is for, did you look at the wiring diagram on http://www.installdr.com ?
Hey guyz Thanks for all your help I got the radio proffesionaly installed and I have further moved on to customizing my vehicle thanks to all that helped and gave their input by the way I ended up wasting around Maybe 300 Dollars on the Purchase of the stereo and the installation and labor fee. Anyway thanks again
lmao, Already did, and am gettin 150 back from damages, lol thanks again cyall around The next time I need your help meaning when I screw something up or someone else cyall later
