CC Door panel pattern
Old May 5, 2020 | 05:12 PM
Thunderkiss1965's Avatar
Thunderkiss1965
I finally amassed a full set of the interior door panel trim for my 65 F100 C.C and need the panels that go inside. I have looked at the stuff on DC and don't care for the plastic they use. I can make custom inserts but I kind of need a pattern, a tracing, a blueprint, something. I can't do it freehand. Anyone got a pattern that I can make full size or any clever ideas?
Old May 5, 2020 | 07:45 PM
Becky_is_a_66's Avatar
Becky_is_a_66
Install the trim to the door with heavy paper or thin cardboard underneath. You can then trace the pattern and use as a template by adding a little around the circumference. That’s how I made my template because I found the plastic repops unacceptable. I transferred the template to the flexible covers that cover up the bottom of big industrial light fixtures (Lexan or some similar trade name). It’s tough and flexible enough to follow the door contours. Glued some padding to it once it was sized correctly and covered with some nice vinyl that was a color and texture I liked.
Old May 5, 2020 | 10:51 PM
RangerMercMan's Avatar
RangerMercMan
Would you be willing to provide a pic of your handy work please?
Old May 6, 2020 | 09:35 AM
Becky_is_a_66
I cut the stuff with a dremel after marking outline with a sharpie
here is the panel installed prior to adding padding and vinyl
Old May 6, 2020 | 11:25 AM
Thunderkiss1965
Great idea Gavin. That will work for a simple man like me. I kind of like the look of the panel as it is in your pic.
Old May 6, 2020 | 12:49 PM
RangerMercMan
Thanks for posting the pics!
Old May 6, 2020 | 01:24 PM
Becky_is_a_66
Here is the panel installed after adding some upholstery padding and a gray vinyl cover to match one of the two tones in the seat cover
Old May 8, 2020 | 12:26 PM
Thunderkiss1965
Looks great!
Suprawill1
Escape & Escape Hybrid
May 25, 2019 01:13 PM
medicpg
18
Mar 25, 2013 10:27 PM
FXDC4419
Jun 27, 2008 10:13 PM
FitchBanjos
Apr 3, 2008 06:15 PM
oldjag
18
Mar 28, 2008 01:46 PM
