Gear pattern feedback
Old May 5, 2020 | 12:25 PM
erickk120's Avatar
erickk120
Thumbs up Gear pattern feedback
Hey guys just curious what you thought of my current gear pattern with motive 4.10's. I started with a .26 pinion shim as my starting point. It was too shallow as I expected it was riding out the face. Jumped to .30 it was getting closer but still too shallow, so jumped to the next shim .36 and it looked pretty close, I tried my luck and tried .38 and I think this is acceptable, I've kept backlash around .007 to .009 which are motives specs.
Here are some pics at .38 pinion with .008 backlash
Here is a link to the library same pinion depth just different amount of marking compound to oil dilution.
https://postimg.cc/gallery/Mf3jJF3
Thanks in advance for the input.
Old May 6, 2020 | 09:45 PM
erickk120's Avatar
erickk120
Quick bump, this is the same specs as above I just took a vid from both drive and coast so that you can get a better perspective, I think this is deep enough, I applied as much drag as possible to the pinion with a rag and turned the ring gear with a wrench, to make it spit a readable patter.
Old May 7, 2020 | 01:07 PM
mark a.'s Avatar
mark a.
I wouldn't mess with it anymore, run it.
Old May 12, 2020 | 10:30 PM
erickk120's Avatar
erickk120
I thought about dropping .002 but I think I will just run this as it seems to get the best depth even though it might be a smidge deep.
chipper
23
Jan 11, 2020 07:42 AM
Backwoods351
1983 - 2012 Ranger & B-Series
Dec 9, 2014 09:45 PM
mortstang
Mar 15, 2010 04:18 PM
Alvin in AZ
Aug 28, 2006 12:51 PM
johnfl
Sep 12, 2001 03:22 PM
