Reared bounce
Old May 5, 2020 | 08:43 AM
66f250's Avatar
66f250
Reared bounce
Hey guys when ever I put my truck (1967 F100 240 I-6 NP435) in reverse the back of the truck bounces. Going forward is no problem. The only time it dident do it was when I forgot to take off the E-break. Not sure if this is one of those " that's just the way it is" deals, of if something is binding up. What do you guys think?
Thanks Joe.
Old May 5, 2020 | 12:06 PM
FuzzFace2's Avatar
FuzzFace2
Check all the rubber mounts.
First the transmission mount then the motor mounts.
Are they cracked / broken or covered in oil?
Maybe because of age just replace them as a start.
What shape are the spring bushings in?
Mostly the front ones as the rears are along for the ride.
Most of the time it is the rubber mounts.
A long shot as it only happens when backing up but oil on the clutch disc from a rear main seal leak?
Dave ----
Old May 5, 2020 | 05:44 PM
66f250's Avatar
66f250
Ok thanks I’ll check all mounts and bushings this week. Another thing the original owner installed some coil helper springs in the rear between the axle and the frame. Would that cause the bouncing in reverse? (I’ll try and get a picture of the rear ended and post it)
thanks
Old May 5, 2020 | 10:11 PM
FuzzFace2's Avatar
FuzzFace2
It should not but it may.
Do you carry heavy loads in the bed and need the springs?
I guess for testing after you check the mounts and spring bushings you could pull them and see what happens.
Dave ----
Old May 5, 2020 | 10:13 PM
ford390gashog's Avatar
ford390gashog
Thanks Joe.
Classic sign of your rear shoes being worn or way out of adjustment. The shoes are " caming" over and binding innthe drum.
Old May 6, 2020 | 06:02 AM
robertrpeak's Avatar
robertrpeak
Agree with gashog, sounds like brakes..
f350rebel7788
24
Nov 19, 2021 09:43 PM
89ford73
Feb 28, 2013 09:33 PM
jas927
Apr 17, 2011 07:44 AM
