Has Fire/Fuel, No Start
Old Oct 16, 2003 | 06:27 PM
jle70's Avatar
jle70
Question Has Fire/Fuel, No Start
I am working on a 1990 Ford F-150 351w. It has fire only with the Spout disconnected. It will not start at all, checked all the ignition parts they check fine. There is fuel to the system, although I can't verify that it is going to the cylinders. Any help would be greatly appreciated.
Old Oct 16, 2003 | 07:58 PM
2Wise4aGM's Avatar
2Wise4aGM
If it has fire only with the spout disconnected then I bet you have an ignition problem, and not a fuel problem.
Old Oct 17, 2003 | 08:19 AM
oceanadec25's Avatar
oceanadec25
You might want to verify timing, you could be 180 out. Otherwise check your pickup coil in the distributor, mine went bad about 4 years ago and it was the last thing to replace. Tough way to get a new ignition.
Old Nov 4, 2003 | 07:44 PM
jle70's Avatar
jle70
Ok, I took it to a shop. They checked it out and found the pcm to be bad. I bought a new/reman unit, installed it and nothing different. The shop said they had the truck running off their computer.
