Slip Yoke * help! *
Old Nov 4, 2003 | 03:15 PM
Cliff Landin's Avatar
Cliff Landin
Exclamation Slip Yoke * Help! *
I posted this message with the subject 'Slip Yoke' and no one viewed it!
I have a '91 F-150 2wd and I am trying to replace a broken slip yoke. The problem is that I can't get the rubber seal on the transmission that the slip yoke fits into off so that I can replace it. It seems to be held in place with a flat metal ring, I just can't figure out how to get the ring off.
If anyone can help it would be greatly appreciated. It's going on four weeks now.
Thanks
Old Nov 4, 2003 | 04:55 PM
c_rossman's Avatar
c_rossman
What I have done in the past is, use a flat head screw driver and tap the metal flange tword the center. Keep doing this all the way around the seal and it should pop out. You have to destroy it to get it out.
Old Nov 4, 2003 | 06:55 PM
Talyn's Avatar
Talyn
Yea, some seals are like that and there is no way around it.
Old Nov 4, 2003 | 07:03 PM
90f150moneypit's Avatar
90f150moneypit
Welcome to FTE.
I realize your new but, you posted the original less than an hour before posting this one.
The best thing to do is simply reply to your own post by typing 'bump' or whatever. This moves the post to the top.
Most everyone on here only checks this after work. Just give them a chance to read and respond to it.
Old Nov 4, 2003 | 08:19 PM
MustangGT221's Avatar
MustangGT221
Welcome to the site!
Just like moneypit said, please be patient, it does take a little time for people to respond. It is important that we keep subject titles accurate so that they reflect what your going to be talking about. It makes it a lot easier for other people using the search feature of the site. Thanks!
