Batch fire or sequential?
Old May 4, 2020 | 11:40 AM
Fordshmord's Avatar
Fordshmord
1994 Ford f250 5.8l 4x4. Which did this truck come stock with?
Old May 4, 2020 | 11:55 AM
wwhite's Avatar
wwhite
Depends on where it was built for. I think some if not all 94s in California were sequential.
Otherwise most likely, it would be batch fire, up until 1996.
If your truck has the stock motor, and looks stock, it probably is stock. Just look to see if it is MAF or SD, look at air box filter box for MAF sensor.
Pretty sure all batch fire are SD, and all sequential injection are MAF.
Old May 4, 2020 | 12:25 PM
jackietreehorn's Avatar
jackietreehorn
I would bet the farm it is batch fire. 5.8 wasn't MAF until 96. Except some oddball California vehicles.
Old May 4, 2020 | 05:41 PM
Fordshmord's Avatar
Fordshmord
Thanks yall, where is the MAF located and what does it look like?
Old May 4, 2020 | 06:17 PM
wwhite's Avatar
wwhite
Where the air filter box is, there is tubes that then go to the throttle body. On the end closest to the air box, there will be a large sensor, it is Mass Air Flow(MAF).
If there is no sensor, it is Speed Density(SD).
Also, SD has 2 tubes all the way from air box to throttle body, and MAF will have one tube, that splits into 2.
Old May 5, 2020 | 01:05 PM
Fordshmord's Avatar
Fordshmord
So I checked for the map sensor it's not on the firewall I can't find it? And the guy removed the air filter box so I'm not sure what's going on
Old May 5, 2020 | 01:43 PM
wwhite's Avatar
wwhite
Does the truck run?
No air box, probably not MAF.
If its SD, then there will be a Manifold Absolute Pressure(MAP) sensor. MAP is located to the right of the heater box, on firewall.
Take some pictures of under your hood, and attach them.
Old May 5, 2020 | 05:15 PM
torq'ta 5 8's Avatar
torq'ta 5 8
is this your turbo truck, if it is it will be hard to tell if PO cant answer, if switched to Mass Air or not, even if MAP sensor is still on firewall
Speed Density has MAP on firewall
Mass Air sensor is connected to Air Intake Filter Box
Old May 5, 2020 | 06:14 PM
wwhite's Avatar
wwhite
Good catch, in the other post, doesn't look like there is a MAP or MAF in the pictures.
I say, pull the ECU, see what electronics is running this thing.
Old May 7, 2020 | 05:23 PM
Fordshmord's Avatar
Fordshmord
I found the map sensor and plugged it into the vacuum tree, runs much better
Old May 7, 2020 | 06:02 PM
torq'ta 5 8
Thats good to hear.
Old May 9, 2020 | 12:08 PM
Fordshmord's Avatar
Fordshmord
Thats good to hear.
thanks for your help man
caspermj
WTB - Ford Trucks & other vehicles
Feb 13, 2013 10:22 AM
HerbertKornfeld
Dec 22, 2003 11:54 AM
