Can’t program new fob
Old May 3, 2020 | 11:07 PM
79n40z's Avatar
79n40z
I just spent the last 45mins researching what I can do to get my truck to get into program mode to program a new fob. I only have 1 at the moment with 1 key so I know I can’t program the key, haven’t had it cut yet, but want to program the fob. I did the whole 8x off/on steps with door open, unlock pressed and even did the wiper thing I found. Nothing 😐.
Is my truck special on this as well ? It was pointed out that my truck with forscan couldn’t get 12v power outs to turn on cause of build date.
anyone have a way to get the truck into program mode ?
thanks Gilbert
Old May 4, 2020 | 12:45 AM
Flyct's Avatar
Flyct
FTE Community Team
Gilbert,
You need 2 functioning key fobs to self program another fob. If you don’t have 2 programmed and functioning fobs you will need to bring it to the dealership or an automotive locksmith.
Old May 4, 2020 | 01:15 AM
79n40z's Avatar
79n40z
Originally Posted by Flyct
Gilbert,
From what I read that’s for the keys, to program a 3rd key you need 2 keys.
for fobs once you start the process it wipes all existing fobs from what I read. Most instructions also have a clause “if only programming 1 fob skip to step 5”.
i can’t even get this to go into learn mode.
Old May 4, 2020 | 01:16 AM
79n40z's Avatar
79n40z
Old May 4, 2020 | 01:26 AM
TeddyD's Avatar
TeddyD
Where did you get the above information? Is it for a Superduty? I am assuming the fob and the key are combined into one unit.
In the owners manual, it does say you need 2 keys to program a third key. It also states you need two fobs to program a 3rd fob which when they state fobs, they mean push start equipped trucks.
Back to the keyed trucks now. When programming a new key, it’s not the key itself that gets programmed, the buttons for the fob get programmed. The key itself doesn’t hold information. Since the manual states you need two keys to program a third, I take it as you will need the two keys to program the fob.
Check your owners manual, maybe I am wrong. It’s been known to happen now and again.
Old May 4, 2020 | 01:38 AM
79n40z's Avatar
79n40z
manual stated nothing. I just used all the search features here, google and YouTube for my year model & key fob found basically the same instructions.
so if the key stores nothing in theory I can swap the actual hard key to the old remote and truck should start as info is on key fob ?
Old May 4, 2020 | 01:40 AM
79n40z's Avatar
79n40z
To add, my key is not a push to start, it’s a keyed ignition
Old May 4, 2020 | 01:52 AM
TeddyD's Avatar
TeddyD
Im not sure exactly how the keys work. I came from Rams which only had fobs and now I have a push start ford. I remember a long time ago in my high school years, I worked at an electronics store. The car installers there had to sometimes permanently install the spare key of a car in the command start module to get the command start to work. One installers told me the that the chip was in the plastic casing of the key and the key itself had nothing to do with it. I’m assuming it’s the same now as it was back then. It makes sense to me.
Old May 4, 2020 | 01:56 AM
TeddyD's Avatar
TeddyD
Try calling a dealer to see if it’s possible to program just the fob and ask how much it would be. If they says it’s possible, you know to keep looking for a free way to do it. If they say it’s not possible, you can stop wasting your time lol.
Old May 4, 2020 | 07:39 AM
79n40z's Avatar
79n40z
Would only having 1 fob present prevent the truck from going into learn mode ?
according to the dash it shows 3 admin keys, although I only have 1
Old May 4, 2020 | 09:42 AM
Flyct's Avatar
Flyct
FTE Community Team
Gilbert,
page 74 & 75 of 2017 SuperDuty owners manual Shows how to program integrated key head transmitter to be able to start the car AND operate the remote entry system. https://www.fordservicecontent.com/F...US_03_2017.pdf
YOU MUST HAVE 2 PREVIOUSLY PROGRAMMED KEYS.
Being you only have one integrated key head transmitter you must either have a dealer or automotive locksmith do the programming. They will connect their computers delete all keys currently programmed into the trucks computer and program your 2 keys.
Old May 4, 2020 | 10:07 AM
79n40z's Avatar
79n40z
Gilbert,
got it, I guess I’m off to the stealership 😞
Old May 4, 2020 | 10:11 AM
drewparker's Avatar
drewparker
This why I always make then throw in a 3rd key as part of the purchase, so when I lose one I still have two. Of course I forgot to do this on the truck I just bought and have an e-bay fob on order
Old May 5, 2020 | 07:55 AM
GABAR's Avatar
GABAR
Hmmm🤔, a third / free key to get a sale?
I really doubt any dealer will throw in one of the current / newer proximity fobs to get a sale especially one of the fobs than don’t have a key for the ignition.
Old May 5, 2020 | 09:05 AM
drewparker's Avatar
drewparker
Nothing is free. You really think a dealer will let you walk to another dealer over the cost of a fob?
