Lug Pattern
Old May 2, 2020 | 10:22 PM
carolinaborn82's Avatar
carolinaborn82
Lug Pattern
I have a 2011 F-150 4x2. Will these new wheels go on my truck. Is the lug pattern the same?
Old May 2, 2020 | 11:19 PM
CathedralCub's Avatar
CathedralCub
FTE Community Team
Assuming the wheel pictured came off an F150 2005 or later or Expedition 2009 or later: Yes 6x135mm bolt pattern
Old May 2, 2020 | 11:24 PM
carolinaborn82
They came off a new F-150. They were swapped out at a local Ford dealership.
Old May 3, 2020 | 02:53 AM
cmorningstar01's Avatar
cmorningstar01
I did the exact same swap on my 2011 FX4
https://www.ford-trucks.com/forums/1...x4-wheels.html
They should bolt on, The only thing you may need are the proper lug nuts, The lug nits on your 2011 have a different thread pitch than the truck these came off of,
Did your 4x2 come with 17" or 18" wheels/tires originally, If 17" with a different size tire your speedometer may be off a little.
Val
Here is a tire size calculator to help you see what the tire size will change the speed
https://www.tacomaworld.com/tirecalc
Old May 3, 2020 | 06:38 AM
gDMJoe's Avatar
gDMJoe
Exclamation
cmorningstar01 ... The only thing you may need are the proper lug nuts, ...
The TPMS sensors will also need to be replaced ...
Also ... Because of the change in the gen'13 (2015+) F-130 rims' mounting surface and stud hole, the lug nuts will protrude slightly more. NBD, it's a cosmetic issue.
Example ...
Additional reference information ...
Old May 3, 2020 | 07:14 AM
carolinaborn82
Example ...
Thank you for the great info. I can drive without the new TPMS, right? I'm gonna get them replaced, just not right now.
Old May 3, 2020 | 07:16 AM
carolinaborn82
Val
Your truck looks great. I think I'm gonna pull the trigger. $600 for brand new tires and wheels is hard to beat. My truck originally came with 18's. So the speedo should be fine.
Old May 3, 2020 | 11:25 AM
gDMJoe's Avatar
gDMJoe
Arrow
carolinaborn82 ... I can drive without the new TPMS, right?
Sure. They'll trip the but will cause no harm or issues.
Would recommend getting Motorcraft sensors rather than any aftermarket - quality and less activation, reset hassles.
NOTE: Consider buying -new- from reputable ebaY® sellers (high satifactory ratings) - much less $$$.
Over the past ten years I've purchased 5 sets from various sellers and had no issues.
Old May 3, 2020 | 11:37 AM
cmorningstar01
I second the suggestion of going with Original Equipment Motorcraft sensors, I had sensors put in by the supplier of my tires/rims and they were aftermarket and I have had some issues, mostly radio interference from cell phone and in truck cell phone charges tripping the sensors, they eventually reset themselves but every once in a while I get that Tire Pressure Sensor Monitor Fault with the chime and it can be annoying
l67cooled
Nov 12, 2009 08:51 AM
Justin2233
Apr 21, 2009 02:35 PM
lennyluminum
17
Apr 19, 2009 04:30 PM
05SD
Oct 2, 2005 10:23 PM
hammerdn
Feb 25, 2005 03:00 PM
