dentside vs bumpside frame width
Old May 2, 2020 | 09:09 AM
79flat's Avatar
79flat
Exclamation dentside vs bumpside frame width
Is there any difference on frame width between the 68-72 f250 and the 73-79 f250? Im looking at getting a 68 f250 with a flat bed and it still has the in cab tank. Im looking to at least add the 38 gal tank to the back if theres not difference or minor difference, if i have to fabricate a bracket or mount to work I will if the needs arise.
Old May 2, 2020 | 09:21 AM
73 hi-boy 428 fe's Avatar
73 hi-boy 428 fe
Are you talking 2WD or 4WD? Either way the answer is yes.
Old May 2, 2020 | 10:51 AM
meangreen92's Avatar
meangreen92
The Bumpside cab is two or three inches shorter than the Dentside cab, if that makes any difference. Pretty sure the extra length is behind the seat.
Old May 2, 2020 | 11:50 AM
79flat's Avatar
79flat
Itd be 2wd, just looking to see if i could squeeze that behind axle tank in with none/little modifications if need be so i don't have to fill up almost every week with my commute coming up itll be around 40ish miles daily
sddaltongang
13
Dec 30, 2019 08:06 PM
A/Ox4
May 4, 2013 07:07 AM
97puller
May 24, 2010 08:27 PM
LeadSled1
Dec 1, 2006 04:37 PM
jumps
Feb 16, 2002 01:37 PM
