don't use copper unless you like walking! most copper tubing available to teh general public is a certain type and it will work harden and fatigue. there are special copper tubing that will not do this but they are pricey and hard to find. also note that copper should not be used for brakes or fuel for the same reason and it is actually illegal in most states to do so. do not use rubber the entire length as it is weaker, retains heat, and breaks down. buy premade sections of bendable steel line from the local auto parts store. 5/16 is the minimum you really want to use but 3/8 won't hurt but gets necked down at the fittings (but the larger line aids in cooling). hawkrod
Originally posted by zach007 I would be interested in Stainless braided lines if I could find them. Did you use your original fittings on this hose? Any suggestions?
Also, in another forum I was told the lines needed at least 140 pound pressure rating. Do you know the pressure rating on your hose?
Thanks....
Zach, I merely cut out the "mid" section of the factory steel line and retained the factory fittings (with say 1-2" worth of nipple) into and out of the radiator and tranny. I fastened the braided line to the fittings using regular old stainless hose clamps. You can find braided lines at most speed shops or at Jegs or Summit Racing.
I don't think you have to worry about the pressure rating on braided lines. I think it is much higher than 140 psi, but I don't believe there is nearly that much pressure running through cooler lines anyway.
I used the rubber tranny hose for both runs (I was in a hurry) This is some thick tuff stuff- I used double clamps on the ends and wire tied it up real good. So far so good, but I would like to make some good metal ones soon- Man that hose was spendy- like 3 to 4 bucks a foot- Should have done it right the first time
carfull, I got kicked out for two weeks for trying to let sombody know of a vendor using "secret code" hahahahaha
-Seriously I was pissed, I've learned my lesson though
well I use to use fuel rubber line it would get hard and crack after 3 years but now they make regular "rubber" line for the tranny ol auto zone has it works good .
I've used small sections of the rubber power steering return hose to connect the tranny lines to cooler. Worked fine. I've also used a roll of seamless steel tubing.
