Gas gauge problems
Old Aug 5, 2020 | 10:37 AM
casetruck1's Avatar
casetruck1
I ran into the problem with mine but i am using poly tank from mid fifties. I ended up grounding the sending unit on the top of tank to frame. I also at one time had some issue with not registering properly and found that the sending unit was not moving with the fuel level. It had gotten stiff had to remove tank and free it up. I am running auto meter gauges and sending unit.
Old Aug 5, 2020 | 02:38 PM
sjahnke's Avatar
sjahnke
Did you measure your tank and configure the sender for that specific size tank? It sounds like the sender insertion depth is too short, the pivot point on the float arm needs to end up midway between the top and the bottom of the tank. I've replaced a sender in a 53 and one in a 56 and they were tricky to get just right. Good luck .
Old Aug 9, 2020 | 08:59 PM
rio68's Avatar
rio68
I'm in the middle with the adjustment...got it grounded with a separate wire...still doesn't seem right.
JTRH
May 5, 2017 10:58 AM
Birken Vogt
Sep 18, 2016 07:35 PM
Idlewild24
Jun 3, 2014 11:55 PM
arrowheadfred
Jan 7, 2011 08:37 PM
natureboy
Dec 9, 2010 01:36 AM
