Heater core???
Old Feb 8, 2001 | 11:20 PM
jimrb's Avatar
jimrb
Heater core???
Have 1996 F-150, 125,000 miles. Loses coolant slowly, noticed musty smell and saw it was wet under the carpet. Sound like a heater core going?? Has not been wet thru the carpet. If it is the core, is this a greatly involved project?? A buddy also said while I (or the mechanic) am down there I should have the a/c evaporator replaced, as it is the same labor to do it by itself possibly later down the line. Thanks in advance for any help !!
Old Feb 8, 2001 | 11:36 PM
thecoppercowboy's Avatar
thecoppercowboy
Heater core???
You can get to the heater core by splitting the box under the hood by the firewall. It really isn't such a big deal. As for the evaporator, you would have to charge down the freon before you can open the lines. If the A/C's holding a charge, I wouldn't mess we it. When you have the heater core case open, spray some Lysol into the plenum to take care of the musty odor.
Old Feb 9, 2001 | 12:08 AM
PAUL_2's Avatar
PAUL_2
Heater core???
The heater core is accessible from inside the truck . Remove the glove box , There is 7 or 8 screws to remove the cover to gain access to the heater core . Other than removing the hose clamps from the core under the hood , its all interior work .
Old Feb 9, 2001 | 12:56 AM
thecoppercowboy
Heater core???
Oh, shoot! You're right! There I go holding the manual upsidedown again. Sorry for the incorrect post. I forgot that I did go under the dash on my '77 F-250. As I recall, it was a little bit of a booger, but what was worst was the weather. Had to leave the door open in the middle of a snow storm. How else was I gonna get any heat?
Old Feb 9, 2001 | 10:23 AM
will's Avatar
will
Heater core???
I done this before on my 1994 F-150. It really isn't that hard except for getting to the screws that hold the cover on the core. Some of them are in tight places and require a short driver and/or socket, and some might need a longer driver to access them. I would test fit all of your tools first.
Old Feb 9, 2001 | 12:22 PM
bsharke's Avatar
bsharke
Heater core???
finlander
2004 - 2008 F150
Dec 2, 2014 10:15 PM
lance65
16
Nov 27, 2013 11:32 AM
coatit
2009 - 2014 F150
Jul 11, 2013 10:27 AM
iceman320
17
Oct 25, 2011 07:08 PM
blancc
1997 - 2003 F150
May 29, 2011 02:43 PM
