Sponsored by: Real Truck
Shocks after switching rear blocks
Old Apr 28, 2020 | 07:09 PM
Codysigmon's Avatar
Codysigmon
Ok so I found out that I’m going to go with 3 inch blocks. My factory blocks are 1 7/8 inches thick so overall it will sit 1/4 inch higher in the back. So when I bought my 2.5 level for the front they sent me all 4 shocks. So now my question is will those shocks most likely work with 3 inch blocks?? I’m removing the factory blocks and putting the 3 inch on so there would be an 1 1/4 ish difference. Does anyone think that I would need new shocks or would the ones provided with the leveling kit work???
thanks.
Old Apr 28, 2020 | 07:58 PM
crusty old shellback's Avatar
They should be fine. If you look at shocks, most say they fit 0 to 2" lift.
Old Apr 29, 2020 | 12:03 AM
Codysigmon's Avatar
Codysigmon
I’m going to try it and see I’m just unsure. I don’t know if I would technically call it a 3 inch lift if I’m removing the factory blocks and going to a 3 inch block. It will only be about an 1 1/4 higher than stock...
Old Apr 29, 2020 | 09:13 AM
Yep, basically a 1" lift is all you are doing.
derek4343
2015 - 2020 F150
23
Apr 27, 2020 05:59 AM
Brian429
2004 - 2008 F150
Feb 26, 2012 05:49 PM
AndeyHall
Feb 17, 2011 08:05 PM
zitman11
Aug 14, 2009 07:20 PM
bc56845
Nov 5, 2006 07:22 PM
