Engine install
Old Apr 27, 2020 | 09:46 PM
67 Merc 4X4's Avatar
67 Merc 4X4
Engine install
Hello all,
I'd like to hear your opinions on the sequence of my engine install. I am working on a 1967 F250 4x4 4spd/NP435 with the transmission currently mounted on the frame less the bolt on bell housing.
Which is the best way to continue installing the engine:
1. Bolt the bell housing onto the transmission then install engine or (assuming the flywheel/pressure plate and clutch are mounted on the engine already).
2. Bolt the bell housing onto the engine then install (assuming the flywheel/pressure plate and clutch are mounted on the engine already).
Any thoughts on this would be appreciated.
Old Apr 28, 2020 | 07:39 AM
Freightrain's Avatar
Freightrain
I've left the bellhousing on the transmission before(when just doing a motor swap). Not sure if it is better or not. It might give you a bigger target for alignment? You still have to stab the input into the clutch disc, so make sure that is centered properly.
I think it is kinda 50/50.
Old Apr 28, 2020 | 09:04 AM
kenny nunez's Avatar
kenny nunez
Engine install
To me I always liked having the bell housing on the transmission. If it is an FE style engine I used to just hang the pressure plate on the pilot shaft with the disc on the splines then tighten the pressure plate to the flywheel after every thing is bolted together.
Old Apr 28, 2020 | 06:28 PM
yellow truck's Avatar
yellow truck
One thing I found with my F100 installation - to get the top right engine to bell housing bolt into place (that is looking at the firewall) we had to do it with the engine side mounts removed to get the engine and bell housing low enough. Otherwise the back of the firewall/front of the transmission tunnel interfered with the bolt.
We then pulled the engine up as high as we could and got the mounts on the block.
Old Apr 28, 2020 | 07:35 PM
67 Merc 4X4
Thanks guys, all great advice. Sorry I forgot to mention the engine is a FE 352 as Kenny nunez did question.
Thank you all for your input. Always nice to have other opinions.
I'm getting close to a running truck which has been way too long in the reassembly. I will post pictures in a few months
when I hopefully turn the key for start up.
Old Apr 28, 2020 | 10:11 PM
cbrown9064's Avatar
cbrown9064
I just pulled mine (1967 352 in F-250 4 wheel) for various reasons. I have always found it easier to leave the bellhousing on the engine, when possible. That is how I did the latest pull. Trans will be easier to install onto bellhousing, is my thought.
We will see...
Old Apr 30, 2020 | 06:01 PM
orich's Avatar
orich
Having a 4x4 makes it some what easier getting the input shaft into the clutch dics just by leaving the trans in a forward gear.
Then grab and turn the output shaft an turn it as your pulling the engine inward. I also use 4" long tranny bolts with the heads cut off as guide studs .
Once you've got the motor lined up with clutch splines screw in a 4'' stud in the an lower only to keep it inline as working the to together.
unscrew as needed.. .
usuallybowtie
Oct 10, 2013 10:56 AM
pells49
Nov 14, 2008 09:16 PM
E30tdf
Oct 24, 2006 11:08 PM
67ranchero
Aug 12, 2004 07:26 PM
killer4x4
May 5, 2001 10:24 PM
