low boost pressure
Old Apr 27, 2020 | 04:53 PM
mikemerc2's Avatar
mikemerc2
low boost pressure
recently installed edge CTS2 monitor getting ready to install the hydra but currently have the banks big hoss #4 chip in truck towing heavy 40' trailer only got 11-12psi boost towed ok but thought boost was pretty low on my edge monitor, unhooked trailer took for drive same 11-12psi boost when hard on the loud petal so to test removed chip took same route drove same way got 15-16psi boost stock?? truck had more power with chip in but less boost?? any ideas?? recently installed KC drop in wheel, high flow exhaust outlet with pedestal with EBPV delete, new up pipes, 4" exhaust and added aftermarket air filter to truck all else is pretty much stock any help or ideas would be great thanks
Old Apr 27, 2020 | 09:10 PM
Jdeshler's Avatar
Jdeshler
Do you have a mechanical boost gauge? If so where is it plumbed into the engine?
Old Apr 27, 2020 | 09:45 PM
mikemerc2's Avatar
mikemerc2
It’s reading through the CTS2 monitor that plugs into the OBDll plug, so it’s reading the map input.
Old Apr 28, 2020 | 08:07 AM
Walleye Hunter's Avatar
Walleye Hunter
I'd suggest hooking it up to a scanner and run it and see what it's doing. Are all of your air system connections tight?
Old Apr 28, 2020 | 09:19 AM
Jdeshler's Avatar
Jdeshler
I would start testing fuel pressures at this point. Would you happen to be familiar with the screens in the sending unit, the pre screen in the fuel pump, the fuel pressure regulator, fuel bowl filter and the ICP?
I had an issue with EVERY one of these at some point
Old Apr 28, 2020 | 09:43 AM
mikemerc2's Avatar
mikemerc2
- screens in sending units?, prescreen in fuel pump? did already put new fuel filter in, upgraded blue spring on fuel pressure spring, icp checked out and know its not leaking at plug but 7.3's are new to me so learning as I go!
Old Apr 28, 2020 | 09:44 AM
mikemerc2's Avatar
mikemerc2
will be checking for leaks this weekend making sure no leaks
Old Apr 28, 2020 | 01:32 PM
Jdeshler's Avatar
Jdeshler
yes, the . Cylindrical screens inside the fuel tank
okay, that eliminated that possibility
Another possibility checked off
Okay, no oil, good deal. Oil in the plug gives the pcm fits. Sounds like you're already very familiar! Get a pressure reading off the fuel bowl
Old Apr 28, 2020 | 02:14 PM
cleatus12r's Avatar
cleatus12r
Butt-Head
After you spend all that time and money to figure out that it's the way the tuning is written, you're going to be pretty upset.
On that note, there's nothing wrong with the tuning. It's simply a way to get around having the engine defuel under high load conditions.
I wouldn't worry about it and I would keep driving it.
Old Apr 28, 2020 | 02:31 PM
mikemerc2's Avatar
mikemerc2
I did get fuel pressure off bowl that was good, and truck has 2 tanks factory and 88gallon in bed connected to bed tank and all good there confirmed that already.
Old Apr 28, 2020 | 02:33 PM
mikemerc2's Avatar
mikemerc2
Hmmmmmmmmmmmmmmm it can frustrate you!
Old Apr 28, 2020 | 04:22 PM
Jdeshler's Avatar
Jdeshler
Have you checked for impeller shaft play?
There isn't much more to do if all mechanical checks out. I would want to see boost levels on a gauge instead of a screen.
What's fuel psi at the bowl?
Old Apr 28, 2020 | 04:31 PM
mikemerc2's Avatar
mikemerc2
just rebuilt turbo and installed new KC billet wheel, forgot what fuel pressure was at bowl thinking 60psi? I will try to set up gauge I can read in cad to compare this weekend
Old Apr 28, 2020 | 07:17 PM
aawlberninf350's Avatar
aawlberninf350
It's a Van Gogh
So the low boost MAP reading seen on the display is what the tune shows the PCM to prevent an overboost code, not actual boost?
With a "real" boost gauge you'd never even know that was happening.
Old Apr 28, 2020 | 07:20 PM
cleatus12r's Avatar
cleatus12r
Butt-Head
Yes. That is why his boost level actually reads higher on the OBD2 data stream when he's in a stock tune than it does with the modified Banks calibration. Like I said, there's nothing wrong with the way it's tuned as long as you know that the numbers you're getting from the data stream are skewed.
