Manual swap
Old Apr 27, 2020 | 02:32 AM
Crimson_Gambler's Avatar
Crimson_Gambler
Manual swap
96 f150 2wd 4.9 300
went mudding yesterday and blew my tranny. Kinda been wanting to throw a manual in it for a while so I think this all be the perfect time. What specifics am I looking for this swap?I found a 95 f150 2wd 4.9 with the 5 speed in it. Is it compatible? Will it just bolt right up? What all do I need to grab off of the 95?
Old Apr 27, 2020 | 06:24 AM
arse_sidewards's Avatar
arse_sidewards
Yes, the 300 shared the smallblock bell-housing bolt pattern and everything but his is solidly in "if you're asking these questions you're gonna screw it up" territory.
Old Apr 27, 2020 | 06:43 AM
tjc transport's Avatar
tjc transport
i ain't rite
you need to grab everything the trans touches, plus all the clutch stuff. best thing would be to get the two trucks in the same place, this way you will have everything you need on hand without running back for missing parts.
Old Apr 27, 2020 | 12:23 PM
Crimson_Gambler
Is the flywheel on the 95 internally balanced or externally? The clutch. Does it have manual linkage or hydraulics?
Old Apr 27, 2020 | 01:29 PM
tjc transport
i ain't rite
clutch is hydraulic.
no idea on balance other than it will be the same between 95 and 96
Old Apr 27, 2020 | 05:00 PM
matt167's Avatar
matt167
you have a '96, so you need an ECU for a '96 300 5spd. ' 95 won't work as ';96 is OBD2
Old Apr 28, 2020 | 12:35 PM
Crimson_Gambler
Just plug and go with the "new" ecu?
Old Apr 28, 2020 | 02:56 PM
irhunter's Avatar
irhunter
Why not just run the '95?
You mud in a 2wd truck? Not time to find a 4x4?
And, finally, if I was going to the trouble of a swap, I would look for a ZF5 out of a F250.
Roy
Old Apr 28, 2020 | 05:22 PM
matt167's Avatar
matt167
Roy
He's got a '96 truck. Engine is basically the same but wiring and ECU is very different
Old Apr 29, 2020 | 04:07 PM
Crimson_Gambler
Would a zf5 bolt up nicely to a 300?
Old Apr 29, 2020 | 04:11 PM
Crimson_Gambler
What kind of zf5 am I looking for specifically if i were to go that route? Would it have to come out of a 96 300 f250? I found one out of a 89 f250 with 351 4x4. Does it have to be 2x4?
Old Apr 29, 2020 | 07:12 PM
Conanski's Avatar
Conanski
Did you really or did you maybe just knock an electrical connector off? What symptoms does the trans exhibit… slipping with a lot of smoke or a sudden loss of forward gears and a check engine light?
Old Apr 29, 2020 | 07:22 PM
Crimson_Gambler
Horrible clanking sound when dropping gear from park to reverse all the way down. When in drive it doesn't wanna go out of 1st even when dropped into 2nd it stays in 1st
Old Apr 29, 2020 | 09:56 PM
4SpeedStickMan's Avatar
4SpeedStickMan
If you are "mudding" a 2wd and blew the auto that ****heap mazda tranny wont last long either.
Old Apr 30, 2020 | 05:22 AM
matt167's Avatar
matt167
The Mazda trans isn't a bad unit. 1st really isn't steep enough, but they are ok
