Steering stabilizer?
Old Apr 26, 2020 | 02:09 PM
Brad ORourke's Avatar
Brad ORourke
Hey fellas, after finally getting the King Ranch back up and running last week, it started having a random, alternating, left/right pulling issue while driving. I quickly came to the conclusion it was my steering stabilizer causing the issue. The str. stab. is less than 2 years old with maybe 15k miles on it. It is a single dampener, and I think it is a Monroe but not positive. What are your thoughts on these? Best brand/durability, single or double dampener? Oh and my truck has small lift w/ 36” tires, that probably makes a difference.
Old Apr 26, 2020 | 07:38 PM
87crewdually's Avatar
87crewdually
Stabalizers mask symptoms, they don't cause what you describe. Some of the things that can cause your issue are worn tires, rusted tight front axle u-joints, worn tie rod ends, ect..
Jack the front end off the ground and have someone wiggle the steering wheel side to side while you look for loose parts. This would be a good start.
Old Apr 26, 2020 | 11:30 PM
Brad ORourke
I agree with you totally, but the steering stabilizer is definitely screwed up. After I removed it, when I compress or extend it, there is a 1.25” dead spot and when it finally “grabs” it is real hard then gradually smooths out.
steelandspeed
16
Aug 11, 2019 04:27 AM
MILAGRO33
Mar 27, 2019 04:59 PM
Nairns05
Mar 11, 2008 11:02 PM
X_Hemi_Guy
Apr 10, 2007 12:51 PM
Customz
Dec 23, 2004 11:59 PM
