Rubber bushings?
Old Apr 25, 2020 | 10:49 PM
THE_PVZ's Avatar
THE_PVZ
Rubber bushings?
Forgive me if this is a previously covered topic, but my searching through these forums and on the greater web did not yield any answers, or at least not the one I was hoping for.
I want to start going through the suspension on my '93 250 4x4 manual 460, and all I can find are poly bushings. My problem with poly bushings is that they eventually start to squeak and I cant stand it. I don't want to be another redneck with a squeaky old Ford so I am on the hunt for rubber bushings but I can't locate them. Have you guys had any luck in this area? Will I have to go through Ford?
Also one supplementary question: Im going to give my steelies a sprucing up but I don't know what color the stock wheel paint is. Id like to match the stock coating. Does any one out there know?
Old Apr 26, 2020 | 07:24 AM
MR KROGOTH's Avatar
MR KROGOTH
Rockauto sells rubber bushings.
Old Apr 26, 2020 | 07:27 AM
torq'ta 5 8's Avatar
torq'ta 5 8
it takes a little bit, to sort through
Suspension, Steering, Tire And Wheel for Cars, Trucks & SUVs
Old Apr 26, 2020 | 08:55 AM
Tedster9's Avatar
Tedster9
Poly might squeak, but it does hold up. Beware imported el-cheapo bogus "rubber", it often doesn't hold up worth a damn. So maybe the best course is to find some Motorcraft NOS if going that route.
Old Apr 27, 2020 | 03:05 PM
THE_PVZ's Avatar
THE_PVZ
Where does a person find NOS Motocraft bushings?
Old Apr 27, 2020 | 03:25 PM
MR KROGOTH's Avatar
MR KROGOTH
NOS stuff is a pain to find. If you are adamant about using NOS OEM stuff, you'll need the original part numbers, and a way to search for them (like Partsvoice)
https://www.partsvoice.com/partsearch
You can get the OEM part numbers on Rockauto by looking at the crossover numbers.
Old Apr 27, 2020 | 03:59 PM
Tedster9's Avatar
Tedster9
Yep, gotta have a valid Ford part # or #s to search, no matter what it is. Then it's like magic. Check ePay too. I'm told Steele Rubber makes good stuff as far as repro parts are concerned. I don't know if they make those bushings though.
z 97ford1
1997 - 2003 F150
Jun 6, 2016 10:24 PM
Stinky1
Apr 16, 2013 10:22 PM
blcoats
Mar 19, 2013 09:03 AM
jmf66
Mar 19, 2009 05:55 PM
wineman691
1997 - 2003 F150
Oct 17, 2003 12:00 AM
