Tire Replacement
Old Apr 25, 2020 | 07:31 PM
truenorth13's Avatar
truenorth13
Tire Replacement
Hello, My 1976 F250 needs new summer tires. Would prefer to find AT's sized 9.5 R16.5 LT, but where can they be found? Only tires available are Firestone Transforce HT's?? Alternatively, would like to use 16" rims with original outtie wheel covers that I have. Do any 16" wheels accept vintage Ford 16.5" wheel covers? Please comment and let me know your thoughts! Thanks!
CS
Old Apr 25, 2020 | 08:05 PM
truenorth13
Would 33 x 12.50-16.50's fit instead? What max width and diameter would work? It's a 1976 F250 2WD longbox, extended cab.
CS
Old Apr 26, 2020 | 07:31 AM
lafermedavid's Avatar
lafermedavid
Im not sure about your covers fitting,they look real nice,,,,,but you can get steelies up to 1997 16" and that gives you alot of options for rubber,,,I just picked these 1993 up,came with rubber for 100 on facebook market place
Old Apr 26, 2020 | 08:52 AM
tlrtucker's Avatar
tlrtucker
The only 16.5 tires I was able to find were Super Swampers or similar bias ply mud terrains. Never saw anything in an AT or anything less aggressive. They are a dying breed, that's why so many have gone to 16 or 17s.
Old Apr 26, 2020 | 11:54 AM
symonds86's Avatar
symonds86
I think a 235 85 16 is pretty close to your 9.5s, if you know anyone with an 80s or 90s truck with stock steel wheels I would just see if one of your caps fit and go from there
Old Apr 26, 2020 | 12:44 PM
KaBar's Avatar
KaBar
Do the 16" wheels fit over the factory front calipers?
Old Apr 26, 2020 | 01:14 PM
Papa Tango's Avatar
Papa Tango
16.5 wheels
CS, I finally bought some White Spoke 16" wheels from Discount Tire. The price of a new tire from Discount was $250.00 plus depending on brand and availability.
If you go this route, make sure the wheel will fit over the Dual-Piston Calipers, if your truck is so equipped.
Somewhere I have the old hub caps... probably holding lug nuts, brake parts and assorted truck parts that might be needed again some day. Lol
Pete
Old Apr 26, 2020 | 02:12 PM
lafermedavid
Yes running a dana 60 up front and the steelies clear,,,,,,I ve read the alum.16 dont (thicker wall) 16.5 also cleared the dana 60,,,,,,
Old Apr 26, 2020 | 05:42 PM
tlrtucker's Avatar
tlrtucker
Difficult to answer this. Everything I researched was for a highboy (with a dana 44 front), with the dual piston front disc brakes, not sure how this relates to you. From the research I did, about 4 years ago, "most" 16's will not clear, but there are a few. I have yet to hear of a steel 16 that would clear. Again, this is all for a highboy with the dual piston front calipers.
That being said, I went with 16" Pro Comp 1069's that clear the front calipers by maybe 1/8th of an inch. If you're running a non-highboy, I imagine (but don't know) that you'd be ok, since they run a smaller caliper.
Old Apr 26, 2020 | 05:48 PM
lafermedavid
my truck is a hb and they clear dana 60 up front 16 inch steelies
Old Apr 26, 2020 | 06:00 PM
tlrtucker's Avatar
tlrtucker
Oh that's cool. I haven't heard of many steelies fitting highboys.
Old Apr 26, 2020 | 08:33 PM
lafermedavid
yes they came with 16.5,,,,, still have them,,,,,,,quite a few people here have done the swap,to 16,,,,,they helped me out ,they had the dana 60 up front as well 78/79 axle (disk) installed into a 75 f250 4x4 which came with drums all around
Old Apr 27, 2020 | 08:39 AM
KaBar's Avatar
KaBar
I've got a 1976 highboy with the Dana 44 front and dual piston calipers. I'm currently running 37" military take-offs. They've become not very practical especially with my worn out leaf springs. It would be great to be able to run 16" wheels so that I could share tires with my other truck.
There doesn't happen to be a list of what people have tried on this site of the different 16" wheels, does there?
Old Apr 27, 2020 | 09:43 AM
tlrtucker's Avatar
tlrtucker
There might be, but I haven't seen a list. I had heard that the pro comp 1069 in a 16x10 would clear, 4wheelparts down the street said they would but I might need a 1/4" wheel spacer to clear. I bought them anyway with the understanding that I could return them if they didn't fit. Not sure why they wouldn't let me test fit before buying, I figured it was just their policy so I didn't argue. They did fit, but barely. There might be 1/8" of clearance between the caliper and the wheel, but I have yet to have a single issue because of it. I was a little worried about a small rock or something getting stuck in there, until I looked at my other cars and trucks and saw they were all about the same, so I don't worry about it.
If I could do it all again I'd go to 17's.
Old Apr 27, 2020 | 06:52 PM
lafermedavid
rims or rubber? just do a search for tall skinny's
SRBF150
44
Feb 8, 2019 02:45 PM
Smb1913
Nov 7, 2015 07:54 AM
Roger T. Pipe
Jun 14, 2015 05:42 PM
TigerDave94
Feb 16, 2010 10:06 PM
redpower9
19
Dec 7, 2008 08:47 PM
