Modular V10 (6.8l)
Help
Old Apr 25, 2020 | 10:55 AM
Corey Allen's Avatar
Corey Allen
Help
Got an 03 6.8 with 234k. Miss at idle but other than that runs great. Noticed fuel mileage decrease but have replaced #10 COP plugs and new boots. Any suggestions would be appreciated. I do run sea foam and have replaced pcv valve and fuel filter within last 2 months. Air filter is new as well. No codes either.
Old Apr 26, 2020 | 11:26 AM
krewat's Avatar
krewat
FTE Leadership Emeritus
Did you replace all 10 plugs? Do you still have them so you can take a picture and show us? One of the best indicators of how each cylinder is running is the condition of the plugs.
Old Apr 26, 2020 | 11:54 AM
Corey Allen
Yes. Replaced all 10 plugs and boots. Plugs were ashy and had about 90k on them from talking to previous owner. (Close friend)
Old plugs.
Old Apr 26, 2020 | 01:28 PM
krewat's Avatar
krewat
Nice, and normal... looks to me...
What were the #'s on the plugs?
Old Apr 26, 2020 | 09:16 PM
Corey Allen
You mean the gap? Or part number? New plugs were champion and book said to gap at . 054
Old Apr 27, 2020 | 02:08 AM
Bently_Coop's Avatar
Bently_Coop
Motorcraft or Autolite is typical for Fords. Champion for Mopar.
Did you replace the boots and springs? Any aftermarket coil packs? Denso is recommended for COP's. Have you cleaned the MAF sensor?
Old Apr 27, 2020 | 11:14 AM
Corey Allen
All plugs springs and boots replaced. #10 coil replaced with NAPA coil. I recently within the last 3 weeks ran sea foam through the vacuum line (brake booster) due to pinging when acceleration. Helped but within a week came back which led me to replace boots springs and plugs. Also just dumped two cans of sea foam into gas tank. 27 gal of gas. Pinging is gone now after plug replacement.
Old Apr 27, 2020 | 02:20 PM
Corey Allen
Thinking maybe a clogged injector?
Corey Allen
Apr 26, 2020 11:48 AM
bebyb
Apr 7, 2014 07:18 PM
sprintnut
Nov 11, 2007 10:55 PM
DirtSquirt
1983 - 2012 Ranger & B-Series
Oct 24, 2004 03:49 PM
kilted_drummer
1978 - 1996 Big Bronco
Jul 31, 2002 03:28 PM
