Ok I'm the dumbest smart guy you'll ever meet. I've got a '93 f150 w/ a 4.9l. What wires go where on the starter relay? Does the S stand for solenoid or switch? I've got a basket case I'm trying to get running, how many wires and where should they go? I've got so many wires running to this thing it can't be right!
Also, where's the brain? Plus, in my Power Distribution Box there's no label on the lid and I can't tell which relay is which! Please help an idiot!
Reason: Incomplete
starter relay wires all go to battery side except for two. the one that goes to the starter goes on the other big lug, and the small push on wire goes on the "S" terminal.
Then what's the black box under the instrument panel that they're also calling the PCM?
It has two plugs w/ about 12 wires going to it. I did find the brain in the driver's kick panel. Thanks
Reason: I
