Explorer 5.0 2001 engine mod question
Old Apr 24, 2020 | 04:31 PM
captainmarkpaul's Avatar
captainmarkpaul
5th Gear
Hello this is my first post on the forum. I bought a 34 Ford project and it came with what I think is a 2001 Explorer 5.0 drivetrain. I have all the parts needed, wiring harness,ecm, and all the sensors. It has GT40 heads and distributorless with the coil packs. My concern is that all the wiring involved will make it unattractive and complicated in a street rod.
Can this engine be converted to use a distributor and the intake changed and carbureted?
Any ideas would be appreciated. Thanks.
Old Apr 24, 2020 | 09:11 PM
Conanski's Avatar
Conanski
Originally Posted by captainmarkpaul
Can this engine be converted to use a distributor and carbureted?
Yes, underneath the EFI stuff it's the same 302 it's always been.
Old Apr 25, 2020 | 06:50 AM
captainmarkpaul
5th Gear
Thanks for the comment. There is a plug where the distributor fits in, so it is safe to assume there is a gear on the cam for it?
Mark
Old Apr 25, 2020 | 06:59 AM
captainmarkpaul
5th Gear
Mark
Also does that mean I can ditch the EEC 4 system and just use a coil and distributor?
Old Apr 25, 2020 | 03:09 PM
Conanski's Avatar
Conanski
Yes, the stub inserted where the distributor goes is a magnetic pickup used for timing with the distributorless ignition system, so you just have to pull that out and plug in a distributor that works with whatever ignition system you want to use like points, duraspark, msd, etc.
Old Apr 25, 2020 | 04:50 PM
captainmarkpaul
5th Gear
Thats great news and I thank you for that. The A4OD transmission appears to be electronically controlled. Is there a way to make that work without the EEC4 processor or do I have to swap it for an earlier model transmission?
Thanks.
Old Apr 28, 2020 | 04:45 PM
fl1a's Avatar
fl1a
The transmission has electronic controls that are a function of the engines' control module. You will probably need an older transmission.
Old Apr 28, 2020 | 07:03 PM
Conanski's Avatar
Conanski
There may be a stand alone controller for that trans (4R70w) but it won't be cheap. Using the factory PCM is an all or nothing type situation, you have to keep the EFI on the motor as well as add some vehicle specific pieces if they cannot be eliminated with tuning.
Old Nov 14, 2023 | 06:28 PM
geezer40's Avatar
geezer40
1st Gear
belt drive
How did you handle the serpentine belt drive. I have the same type of project going electronic to distributor and carb. No AC or power steering. I know your post is from 2020 but I just came upon it. Thanks for any info you can share.
Old Nov 14, 2023 | 06:55 PM
captainmarkpaul
5th Gear
With the distributor I will have to make a new bracket to relocate the AC compressor if I use the carb and distributor. Still on the fence on which way to go.
Old Jan 14, 2024 | 04:10 PM
shaker666's Avatar
shaker666
The EEC-V controlling that drivetrain package is superior in all respects to any carbureted junk that’s got distributor ignition. I have several hot rods all running Ford injection with EDIS, it is fully tunable and dead reliable.
Old Sep 2, 2024 | 10:59 AM
cpwtech's Avatar
cpwtech
1st Gear
Smile
I have an 86 F-150 and all I did was take all the drive belt setup off of the old engine and swapped it over to the 01 5.0. It runs like a champ and has been for the past 4 years. It seems to have a bit more pep in it's step.
Hendrik
Mar 11, 2017 02:50 AM
crazy96863
Apr 22, 2013 08:20 PM
Country705
Apr 20, 2013 11:04 PM
sawtooth
2011 - 2019 Explorer
23
Oct 30, 2011 11:10 AM
Dawg_enD
1966 - 1977 Early Broncos
Aug 14, 2003 01:41 PM
