Parts
Old Apr 22, 2020 | 08:20 AM
JimiT's Avatar
JimiT
Parts
Does anyone know if the wheel cylinder for the front drivers side is the same on the 350 as the 250? PN? I am putting in an order from LMC trucks but they only list for 100 and 250.
Second question is the line going from the oil pan to the pump is leaking at the fitting on the oil pump but only when I shut down, I have tightened it and it stops leaking for a few days then manages to start leaking again. Is there an o-ring or seal of some sort, I have been unable to find a parts diagram of mine anywhere.
I'm soon going to have to invest in a parts manual.
Old Apr 22, 2020 | 09:22 AM
Tedster9's Avatar
Tedster9
Welcome to FTE!
That sounds a lot like the external oil pump on 292 Y-Block. Yes, there is a rubber gasket. It looks a lot like a 1/2" or so chunk of black garden hose basically. It is crushed as the fitting is tightened and expands to form the seal. It has probably turned to stone by now. Overtightening the fitting won't help any, it's the rubber seal that does the work. A small amount of Permatex thread sealant will help keep any subtle air leaks from forming.
Old Apr 22, 2020 | 09:29 AM
TA455HO's Avatar
TA455HO
Lead Gopher
Front brake cylinders are a different part number between a 1964 F250 (C1TT-2062-F) and a 1964 F350 (C1TT-2062-A).
Old Apr 22, 2020 | 03:27 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Please, when asking questions, list ALL the pertinent info. What year is the F350?
Your "About Me" profile says 1964 F350, If this is what you're working on...
1961/64 F250 2WD: C1TT-2061-F Right & C1TT-2062-F Left .. Front Wheel Cylinders - 1 1/8" diameter / Obsolete
1961/64 F350: C1TT-2061-A Right & C1TT-2062-A Left .. Front Wheel Cylinders - 1 1/8" diameter.
Not the same, notice that the suffixes are different.
Old Apr 22, 2020 | 03:39 PM
charliemccraney's Avatar
charliemccraney
To add to what Tedster said, over-tightening that nut will eventually crush the tube, at which point it will not stop leaking until the tube is repaired or the pickup is replaced.
There is a torque spec for that nut and it is far lower than it would be ordinarily for a thread that size. I don't recall the spec and I'm not going to guess and provide incorrect info. Look in your shop manual, if you have one. Get one if you don't. There's also not a very good way to torque it so best to know the spec so that you know what you are aiming for.
Old Apr 23, 2020 | 11:33 AM
JimiT's Avatar
JimiT
I'm working on a 1964 F350,
Anyone have a part number for the oil pump seal? I tightened it twice as it seemed the first time it was lose, second time I was carful not to twist the line off but gave it about a 1/4 turn. I guess ill have to invest in some crows feet for my torque wrench.
I found wheel cylinders and some rebuilt kits at rock auto be here in a week or two.
I have been having trouble finding front shocks, anywhere that is affordable, I have been using rockauto and LMC because the shipping to Canada is not to bad, but nether list front shocks for a 350.
Old Apr 23, 2020 | 12:08 PM
TA455HO's Avatar
TA455HO
Lead Gopher
I have been having good luck with the Autolite shock absorbers. Armed with the part numbers from the master parts catalog they are easy to search for. These are for the rear of my F250. F350 might be available, too. Of course, anyone might say old unused stock shocks are worthless, too.
Old Apr 23, 2020 | 01:33 PM
Tedster9's Avatar
Tedster9
B4A-6698-A should get you started on the oil seal. Might be an updated # for that, I dunno.
Something about the metal insert, maybe @charliemccraney
can add to that. Thing is too some of the NOS might be dry rotted by now.
Old Apr 23, 2020 | 02:28 PM
charliemccraney
The Fel-Pro inlet tube seal uses metal sleeves, in addition to a rubber component. This design is more prone to failure right from the start and I've had one with defective inner sleeves, which prevented a seal. I've also used the Fel-Pro without any problems. As long as the sleeves are good and the tube is round, it should be fine but there are better options. Best Gasket, and others produce a rubber seal and that is the most fool proof. Do not use only the rubber seal of the Fel-Pro part as the inner diameter of that rubber part is a little smaller than the ID of a seal meant to go directly on the tube.
You will also need an oil pump gasket or oil pan gasket set. You will not be able to get the tube out with the pump or pan in place. One or the other has to be removed.
Old Apr 23, 2020 | 05:45 PM
JimiT's Avatar
JimiT
My front shocks are very different
Old Apr 23, 2020 | 05:59 PM
TA455HO's Avatar
TA455HO
Lead Gopher
Sounds like one of the types of shocks used was same as the rear on earlier cars and some were same as some of the F500/700 trucks. You can get the details here. McDonald listed still shows the two in stock that they did then. You have to call to see if they still have them. Must not be a lot of aftermarket demand for shocks for a 50+ year old 1 ton+ Ford truck.
https://www.ford-trucks.com/forums/1...l#post17849150
Hopefully they can help. Old shocks seem fine once you pump the air out of them which is simply done by actuating them a few times. As long as the seals haven't shrunk.
Old Apr 24, 2020 | 06:56 AM
JimiT's Avatar
JimiT
Thanks, parts in general seem scarce for the old 1 ton.
1977ford250
May 27, 2009 09:02 PM
websthes
British Columbia
13
Oct 4, 2007 10:36 AM
RyanJake
Feb 22, 2007 10:33 AM
Chris-jack
Dec 18, 2005 10:01 PM
aerocolorado
General Automotive Discussion
Mar 22, 2005 07:13 PM
