Help!!
Old Oct 16, 2003 | 09:20 AM
Drewk77's Avatar
Drewk77
Question Help!!
I have a 2000 Ranger, about 2 weeks ago while driving, the ABS light and check engine light came on. Also the speedometer doesn't work, and the transmission is having a hard time knowing when to shift. (it sounds like it can't decide if it wants to be in overdrive or not) So what do you folks think??? Please let me know!
Old Oct 16, 2003 | 10:04 AM
02PSD4ME's Avatar
02PSD4ME
Sounds like the ABS sensor
Old Oct 16, 2003 | 11:58 AM
PSKSAM2's Avatar
PSKSAM2
Welcome to FTE! Sorry to hear about the problems.
You may want to go to Autozone or another place that will read codes and find out the code that is causing the Check Engine Light. This will help you get a clearer answer on the problem. Be sure to let us know what the code is, I'm sure someone here can look it up.
Old Oct 16, 2003 | 12:26 PM
Ken00's Avatar
Ken00
Sounds like the VSS (vehilce speed sensor), its on top of the rear, one bolt and an electrical connection. This is a common problem and everything you listed runs off of information from the VSS.
Old Oct 18, 2003 | 11:40 AM
Drewk77's Avatar
Drewk77
Thanks
Thanks for all the help, I will get on this ASAP and let you know the results.
Old Oct 18, 2003 | 11:49 AM
Drewk77's Avatar
Drewk77
will I have to go through the dealership to get the speed sensor?
Old Oct 18, 2003 | 02:04 PM
Ken00's Avatar
Ken00
I don't think its dealer only, give your local parts store a call.
