Does it not move at all or does it only move part of the way? Solution 1) The cable the goes from the column to the needle is broken. 2) There is a thumb wheel adjuster to align the pointer.
it doesn’t move at all. I tried looking for those two things and couldn’t find them. Are they behind the gauge cluster?
Be careful? There isn’t a whole lot of slack in the two wiring connections and even less in the speedometer cable. Find someone with small hands to reach behind the cluster?
Been there, hunted down neighbors with smaller hands! I'm must thankful that by the time my '93 rolled out they'd gone to electronic speedos and had learned to spend a few cents on longer wires.
Still a bit of a fiddly mess taking the cluster out, but the old stumbling blocks are finally gone.
