Poor Man's Coyote PS bracket
The F150 coyote before I started
Doing a little CAD cardboard added design.
Grinding down the pedestal for the idler pulley. Unfortunately I was unable to keep the idler or the tensioner.
I will add more slowly. As a heads up I have ran my set up and as of April 2020 I probably have 500 miles on it with no problems so far that are show stoppers.
For modifications to the timing cover I had to grind down the idler mount and tap the two standoffs. One is tapped to 10m-1.5 and the other is 8m-1.25.
Installing the mustang belt
Gates recommends this little gauge for belt tension.
testing the tension on the stretch fit belt.
Pump bracket modeled.
Pictures of the pump setup.
I will add pics with reservoir once I take them.
- Power steering pump is off a 1995 Camaro with a 5.7l
- Belt is a K060392SF
- Power steering pulley is a Dorman 300-130 for a Pontiac 2008-95 grand Prix
- Power steering reservoir is a cheap BMW model off eBay. Search BMW ps reservoir and you will find it.
- Bracket spacer lengths are 0.86", 1.54", and 2.635". Your milage may vary to check your belt. Mine was was within 10-30 thousand.
I know some people would prefer a slotted bracket that can be adjusted but I wanted a design that could be made in anyone's garage. I may consider a slotted one down the road but if this design continues to work well I will probably not mess with it. I may look into a supercharger version if I go that route but do not hold your breath.
CAD files link
Anyone is more than welcome to make their own version or improve on the design. Feedback and new designs are more than welcome.
The 11+ f150s are electric assist rack and pinion. I got the stretch belt idea because that is what the 11+ mustangs used for the ac compressor belt.
The pump does leak some from the main shaft. I assume this is because it is a cheap remanufactured pump. I bought a new pump but it was not reverse rotation even though it said it was. That was a frustrating day. You can put some oil in it and see what way it is flowing prior to installation. I suggest doing this.
I have looked into buying a aftermarket performance pump but they use bearings instead of bushings and that would not work with the pulley I have. Changing to a different pulley means I have to design a new plate. It's not great it leaks but has not been a show stopper so I keep running it as is.
Pics:
Any chance that you know the length of the spacer?
edit; I just noticed you had the dimensions in one of the posts.
A cheap guy can be the mother of invention!
CAD files link
THe Corvette pump uses a smaller pulley shaft so it will not work with the pulley I used. I think the pump would bolt to the bracket but the stretch belt would need the exact same size pulley.
I could not find a pulley with the same diameter as the one I used that would fit the smaller Corvette pump shaft. If I had it to do over again I would use the Corvette pump since those are available aftermarket.
It powers my hydroboost and steering without any problems.
